P0101 issue
Old Jan 15, 2021 | 09:59 AM
Keep it clean and drive it often!!
Old May 8, 2021 | 05:46 PM
FlawdaSS's Avatar
man I'm having the same damn issues. i have new stage 3 map sensors coming along with the tune from ZZP. i bought the car recently with 152k on it. bought a new MAF and it is still doing it. new filter as well. SPectre from advance. i have a fake CAI. essentially the stock MAF housing with the filter stuck on sitting just over the valve cover. it was fine when i bought it but i sprayed under the hood with a pressure washer from the car wash and this **** started and won't go away. i took off all the connectors and sprayed them with compressed air in all the areas i washed. still no luck.
Old May 8, 2021 | 05:53 PM
Water got into some connector. Are you looking at the MAF or the TMAP? If the car has the Stage 1 GMTU upgrade installed there are a couple of places to look, like the TMAP connector banging into the AC compressor and if the wiring harness was soldered and sealed or just crimped.
Old May 8, 2021 | 06:13 PM
Water got into a connector in the harness, which would short out the signal and fry something or other. I do not recommend pressure washing near the electrical connections, nasty things can happen.
Old May 8, 2021 | 07:09 PM
FlawdaSS's Avatar
yeah it appears as such. its weird tho. done this on countless cars and no issues. its my fault tho. just wish could get it fixed. i will clean the intake tubing and throttle body as well tomorrow.
Old May 8, 2021 | 07:20 PM
So you sprayed high pressure water all over, with an open element air cleaner. I don't see where you tried a new filter.
Old May 8, 2021 | 07:39 PM
FlawdaSS's Avatar
Help
I am getting the mass airflow sensor cold but for some reason it clears and then comes right back. I was looking at a few other videos were people have the same issue and they cleaned the throttlebody as well. I am just going to hope that it dries up and get me back to normal. This is getting really old.
Old May 9, 2021 | 06:29 AM
You might need to take it apart, let it air dry, then reassemble. But there might still be electrical damage from the water!
Old May 9, 2021 | 06:57 AM
Stage "3" map sensors ?
Old May 9, 2021 | 08:54 AM
ZZPerformance has a Stage 3 kit for turbo Cobalt’s and Ion’s maybe they are in that kit, but would really still be the Stage 1 sensors from Bosch.
