P0101 issue
Old May 9, 2021 | 07:10 PM
FlawdaSS's Avatar
Originally Posted by Oldblue
You might need to take it apart, let it air dry, then reassemble. But there might still be electrical damage from the water!
Well gents I got it fixed. Took out the two pcm plugs, maf plug and ignition coils. Cleaned then with contact cleaner and put them back. Connected the battery and boom. Boost is back.
Old May 9, 2021 | 07:50 PM
Awesome , keep it clean and drive it often.
Old May 9, 2021 | 08:09 PM
FlawdaSS's Avatar
Spoke too soon. Code came back. Fml
Old May 10, 2021 | 08:58 AM
Then we know it is a frayed wire/ bad crimp.
Old May 10, 2021 | 09:01 AM
FlawdaSS's Avatar
Frayed wire?
maf sensor plug?
Old May 10, 2021 | 09:31 AM
  #26
I re-read your post, I did see the new air filter. A "fake" CAI? You actually have a HAI( hot air intake).
I don't see that it has a stage 1 tune. He said he ordered TMAP sensors and a tune, they're on the way. So there are no soldered or crimped connectors(yet). I'm hoping that the plug and play adapters were ordered.
Old May 10, 2021 | 09:34 AM
  #27
FlawdaSS's Avatar
I ordered the ZZPerformance map sensors and tube. The mass airflow sensor is the issue I'm having. I'm gonna check fuses and see if the plug is not bad
yes it's a hot air intake. Lol
Old May 10, 2021 | 03:24 PM
  #28
The crimps I meant are the stock pins in the connectors. Sometimes the wire gets frayed or corroded, making for intermittent problems. The fact that diddling with the wires temporarily fixed it leads me to believe one of the pins is loose or broken.
Old May 10, 2021 | 03:38 PM
  #29
FlawdaSS's Avatar
Gotcha. I may just get this **** coded out. It's exhausting
Old May 10, 2021 | 04:03 PM
  #30
Or that the battery lobotomy, while he did the work, cleared the code and bought some time with good boost.
