Performance Output from Interceptor Gauge
Has anyone run the performance reading on the interceptor gauge? I just ran it for the first time this weekend. Was wondering how accurate the output was. I took of picture of the output but it's crappy.
0-60 = 5.77 sec
1/4 mile = 13.91sec @ 103 mph
1/8 mile 9.06sec @ 82
0-60 = 5.77 sec
0-30 mph = if you spin the tires up to 30 mph it will be optimistic since it thinks you are going that fast when in fact the tires are but you are "not"
0-60 mph = accurate
1/8 and 1/4 mile ET = optimistic since it measures tire rotations, so again wheelspin is distance not actually covered.
1/8 and 1/4 mph speeds PESSIMISTIC. In other words it will read slower than your actual speeds since it will give your speed based on distance it thinks you covered based on wheel rotations.
If you make a run without significant wheelspin, it will be very accurate if the loaded tire radius parameters are correct.
agentsmith23
Aug 14, 2008 09:15 PM
