Possible to switch the ss to ls or lt knuckles?
Old Feb 7, 2024 | 01:35 PM
Bazzertwaz's Avatar
just looking for some info I tried searching and came up with nothing. is it possible to switch the ss knuckles bearings/hubs and cv axles to a ls or lt model? or should i take one of those knuckles to a machine shop and bore it out to fit an ss wheel bearing? had a bent knuckle from an accident and I'm having the hardest time finding one.
Old Feb 7, 2024 | 02:23 PM
No. You need the correct knuckle. The ball joint mount is also different. Plus, I believe the geometry may be a little different between the 2.
Old Feb 7, 2024 | 04:14 PM
The SS axles are probably too big to fit through the LS/LT knuckle.
Old Feb 7, 2024 | 05:17 PM
Parts are getting scarce, check auto recycling yards I don’t see anything online at this time.
as for swapping in the LS/LT knuckles you would have to measure side by side, pretty sure they are completely different.
Old Feb 7, 2024 | 06:09 PM
What side do you need? Here's a left
https://www.ebay.com/itm/334372431504
25923941 Right side
25923942 Left side
Old Feb 7, 2024 | 06:25 PM
PulpFriction's Avatar
Won't be easy but it may be possible to repair the bent knuckle, depending on where and how badly it's bent.
Old Feb 7, 2024 | 10:42 PM
Bazzertwaz's Avatar
the lt ls knuckle fits the ss hub doesn't, sadly I need the passenger side. the knuckle was done it looked like I had stanced one tire. had to replace a lot well ill mess around here and ill keep you all posted had some stamped arms so thought id try that route since the cv axles cost about 30 bucks each on rockauto for automatic. also have an lt knuckle so in theory id just need another knuckle to try this out.
Old Feb 7, 2024 | 11:12 PM
Bazzertwaz's Avatar
fireman you are right the lt one is a bit smaller
Old Feb 8, 2024 | 07:55 AM
Try car-part.com
Old Feb 8, 2024 | 08:29 AM
The part RJ posted a link to is not for an SS , the EBay ad shows the RPO sticker, that was an LT with FE3 suspension
