Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   Power loss when the AC is on (https://www.chevyhhr.net/forums/hhr-ss-45/power-loss-when-ac-42592/)
swerv0428 08-30-2012 04:22 PM
Originally Posted by SmootHHR (Post 666493)
Don't know if this is 100% true or not, but I've heard that when at WOT with the A/C ON, the A/C clutch will disengage until you are no longer at WOT. Had a buddy try it at the drag strip. Turned the air on and pulled the knob off so he couldn't turn it on...ran identical et.
Again, don't know if its true or not or if it was just a fluke on his part.
I'm not sure with the HHR. However I have drove other four bangers that did that. When getting on the highway it would kick the ac off so you had full power.
Father Azmodius 08-30-2012 04:40 PM
I don't remember reading that in the SS manual (I have CRS though ), but I know the wifey's S4 disengages the AC clutch under heavy loads.
Originally Posted by RoadDawg831 (Post 666468)
It's worse with the windows/sunroof open at speed. But I'm blessed with living in a climate that makes that kind of motoring wonderful so for me it's a good tradeoff to being hermetically sealed up all the time. :cool:
I have the RPD set to show fuel pressure and just popping the rear of the sunroof will raise it 50 psi or so at highway speeds.
hyperv6 08-30-2012 08:22 PM
Most cars will kick the AC out at wide open throttle. Also most cars will add a a different tune when the AC is on. Often it will add a little fuel to compensate for performance and idle.
swerv0428 08-30-2012 08:25 PM
Suppose that where the drop in gas mileage goes then?
hyperv6 08-31-2012 07:33 AM
Well think about it. It takes more HP to run an AC unit and more HP = more air and more fuel.
If fuel and more power were not added you would feel more of a drop.
This is nothing new as I could always see a similar change in power and MPG in even the V8 engines. In the past it was even worse when all you had was a selinoid to bump up the throttle on the carb in the pre Fuel Injection days.
Alts, Water Pump, Converters/drivelines, Power Steering, AWD, etc all take power away from the car to run. This is why we have electric power steering that was orignally developed for the Fiero. Once it was canceled they found it to be useful in gaining more MPG.
In the old days 1970 and before they used to rate engine HP as Gross HP with engines stripped of everything on the dyno. 71 and later they went to Net HP and it is an engine fitted with the accesories. That is why some of the engines from the 60 had so much power and only ran 14/15 seconds. It was not only the tires that limited them. Todays engines in Gross HP would have some wild numbers under the old system.
esmarkey 09-03-2012 05:02 PM
Originally Posted by hyperv6 (Post 666120)
I can feel it in my V6 and V8 too.
But on the other hand my Fiero V6 is faster by a couple tenths in the quarter mile with the AC on.
Most cars compensate for this with added fuel but there is still a little feel in all of them even the V8. Drag on the engine is drag no matter the cylinders or HP.
Hyper, how do you explain that??
ChevyGuySS 09-03-2012 05:57 PM
the new chevy cruze shuts off the ac when you step on the peddle and turns it back on when you let off. its to free up that extra hp
