PSI Boost Gauge
Old Aug 6, 2008 | 07:22 AM
BLUEHHRSS5SPEED's Avatar
The gauge should be the same between a 08 and 09 should it not?
Old Aug 6, 2008 | 09:32 AM
Clevelandhhrss's Avatar
It seems that way from the 09 pics.
Old Nov 4, 2010 | 07:30 AM
hhr_2009's Avatar
Do you have a part number, and how was the installation
Old Nov 4, 2010 | 08:24 AM
JeramieJJ's Avatar
Originally Posted by HPVOHHR
For #3, note that the stock gauge is electric... a small harness plugs into the gauge.
As stated, just get it in electrical: http://www.summitracing.com/parts/ATM-6159
Old Nov 4, 2010 | 08:29 AM
gcsd3742's Avatar
Or for $50 more go with the Aeroforce. and it reads every single sensor and then some on the Vehicle....This plugs right into your OBD port
http://www.aeroforcetech.com/
http://www.stylintrucks.com/parts.as...tfamilyid=1717
Here's a few things it reads....
* RPM
* MPH
* Intake Air Temperature (post Intercooler)
* Ambient Air Temperature (pre Intercooler)
* Engine Coolant Temperature
* Exhaust Gas Temperature (PCM Calculated)
* Transmission Temp. (auto trans)
* Manifold Pressure (vacuum/boost) displayed in PSI
* Fuel Temperature
* Battery Voltage
* Battery Temp
* Injector Pulse Width in msec.
* Injector Duty Cycle (%)
* Air Flow Rate into engine
* Long Term Fuel Trim
* Short Term Fuel Trim
* O2 Sensor Voltage
* Barometric Pressure
* Ignition Advance
* Base Spark
* PCM Spark Adjust
* Fuel Status (open/closed loop)
* Wastegate Solenoid Duty Cycle (%)
* Knock Retard
* Knock Sensor Raw Voltage
* Throttle Position Percentage
* Throttle Position Sensor Raw Volts
* Calculated Net Horsepower
* Engine Load
* Transmission Slip
* Current Transmission Gear
* Torque Delivered to Transmission
* Torque Converter lockup status
* Brake pressure
* Brake Booster Travel
* Steering Angle
* Non-driven Wheel Speed
* Lateral G's
* Yaw
* Fuel economy (instantaneous and average)
* P-ratio - pressure ratio MAP/Barometer
* 2 user configurable analog inputs**
andyb
Dec 3, 2010 04:55 PM
hhr_2009
Nov 5, 2010 06:16 AM
