reconfigurable performance display
Got the information on reconfigurable performance display it will mount in center glove box area for HHR.
Here what it will do:
Boost
Air/Fuel Ratio
Spark Advance & Knock Retard
Cam Phaser Operation
Engine Power & Torque
Digital Speedometer
Lateral Acceleration (with peak value store)
Barometric Pressure
Outside Temperature
Battery Voltage
Coolant Temperature
Inlet Air Temperature
Fuel Pressure
Tire Pressures
Shift Lights & Gear Indication
Traction Control Active Indication
Vehicle Stability Control Active Indication
Competitive/Launch Mode Active Indication
The colbalt mounts on the piller
This info is from GM... So glad I ordered it
Now have to learn how to use it
Boost
Air/Fuel Ratio
Digital Speedometer
Barometric Pressure
Outside Temperature
Battery Voltage
Coolant Temperature
Fuel Pressure
Tire Pressures
