Reconfigurable Performance Display
i agree that gm should have made a better cover for it. i also think it is in the best location for visibility. when i get mine, i will fabricate a better cover/mount for it. when done, it will look like a factory install. well, better than a factory install...
Thanks for the pics ChevyMgr!
Im surprised they would add something like this without consideration for styling. It seems obvious to me they should have just covered it with a full width curved cowl similar to the gauge cluster. No more expensive, just would have looked better.
Looks like an old Fuzz Buster.
I am glad I did not wait. I am a little disapointed in how it turned out.
With my scan meter installed all I am missing is the colorful graphics.
I think I would miss the storage more in the dash now that I am using it.
there is one reason why this is better than all of the aftermarket gauges. it has a warranty. the RPD is over 25 gauges in one. it is a:
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
individual wheel tire pressures
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
plus the following indicators:
stabilitrak, traction control, ESC, competition driving mode, and launch mode
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
