Reduced eng performance
Old Apr 15, 2018 | 06:57 PM
tjustice's Avatar
09 ssHHR 56kmi 5 spd reduced eng performance warning came on, went into limp home mode using synthetic oil , the warning system was still set to original system , raised hood everything is still hooked up , IDEAS? TERRY
Old Apr 15, 2018 | 07:12 PM
Check Engine Light on ? Even if it isn't, you need to pull the codes. You have one (or more ) that has triggered the reduced power.
Post them up here (numbers only, no descriptions) and we should be able to point you to the problem.
Old Apr 16, 2018 | 08:15 AM
X2, codes please, and how old is that battery?? Original??
Old Apr 16, 2018 | 08:54 AM
aradmahogany's Avatar
I think normally the reduced power problem is 9/10 times related to the throttle body and/or accelerator pedal, no?
Old Apr 16, 2018 | 09:24 AM
DrLoch's Avatar
Not all the time. OP hasn't provide enough information yet.
Old Apr 16, 2018 | 10:11 AM
tjustice's Avatar
CODE P0087 [fuel rail pressure too low?]
Old Apr 16, 2018 | 10:37 AM
Intank fuel pump or regulator
https://www.obd-codes.com/p0087
Old Apr 16, 2018 | 10:49 AM
HPFP? Or is that a different code?
Old Apr 16, 2018 | 11:26 AM
The HPFP could effect rail pressure, I am sure.
Old Apr 16, 2018 | 02:19 PM
So will the fuel pressure regulator and the low pressure pump, I just read the article for the code, it doesn’t mention anything about HPFP
