ss dash gauge
Does anyone know where I can get one of those stand up turbo displays that goes on top of the dash in the cubby?
RPD is what you are looking for, check Ebay, dealers and junkyards. After 2009 it should just plug in. 2008 may not be wired if my memory is correct.
09
Originally Posted by celblazer
(Post 837390)
Reconfigurable Performance Display (RPD)
And it's much more than just a boost gauge. Since all 2010 SS's had the RPD, that would be the year to search for when looking in a wrecking yard. |
Need
I am definitely looking for one of those RPD’s now. Got a ss panel in my driveway any help would be greatly appreciated |
I am not sure about the "just plug in" on a 2009. I have read that unplugging the RPD will cause the engine to not run, it is part of the CAN bus.
Maybe, I have been misled. |
info
I was reading some where that on a 09 ss the rpd was a option so under the cubby was the rpd plug with a jumper wire installed. So unplug the jumper and plug in the rpd and it would work
Rpd
Still haven’t found one anyone had any luck? |
Go to a local reputable wrecking yard and let them locate one for you. The better yards have the online system that lets them locate specific models across the U.S.
Somewhere there is a wrecked SS in a yard with the RPD. Just might have to talk your local guy into going the extra mile to find one. |
Reconfigurable performance display ( rpd ) for ’09 -'10 chevy hhr ss
I'm not sure if you found what you are looking for but there is a current listing for the RPD. on Ebay. The listing name is 'RECONFIGURABLE PERFORMANCE DISPLAY ( RPD ) FOR ’09 -'10 CHEVY HHR SS' . I was looking for the part number for the plastic insert that goes under the display when I came across it today.
