Sudden onset of fuel delivery issues 08 HHR SS
Hello,
I have a 2008 Chevy HHR SS which I have babied for a few years now, and I have been really loving it. Unfortunately, I went to crank her up yesterday and she sputtered and kicked and blew white and sooty black smoke before the engine died. First research pointed to the fuel pump, and I had been hearing a very light dieseling knock sound from under the hood in that area, so I received a new high-pressure pump and installed today - Now it runs a little longer, but still dies. I went to harbor freight and got a fuel pressure tester - pressure gets to 68-70 and stays there solid with no drop after 5 minutes + . No issues from the pump in the tank. I removed the coil packs and spark plugs, found no issues ( ohm meter checked, etc. ). Looked at the fuse box and could not locate any blown fuses. She has over 1/2 a tank in her I should mention. Throws the p0087 code. Has me stonewalled. Does anyone have any ideas as to what my problem(s) could be? Thank you so much, Andy B. |
:welcomewagon: to the forums!
For $30, I'd be giving this a try. https://zzperformance.com/products/f...ressure-sensor |
Potential causes of a P0087 trouble code may include:
Weak fuel pump, restricted fuel supply line Faulty fuel pump driver module Faulty fuel pressure sensor I concur with RJ and suggest you consider replacing the in tank fuel pump. |
I only see that the in tank fuel pump pressure was checked. What about checking the HPFP pressure ? Should be around 2200 at cold start up and 400-600 at idle after warmup.
( should be able to check pressures with a scan tool) |
A new HPFP was installed
I would make sure all of the wires to the HPFP are good and the connection are tight.
It indicates low pressure after the HPFP, either the sensor, the solenoid or the pump. Conditions for setting the code: actual pressure is 1.5 MPa(218 psi) less than the desired pressure. That is a lot; my guess is the actuator is not functioning at all. |
Originally Posted by Oldblue
(Post 946080)
(Post 946085)
Bottom line, I would be checking the HPFP pressures again. |
(Post 946083)
(Post 946085)
I wonder if a bad injector is blasting excessive fuel. A good reason to use your RPD (for future readers who might have one) or scanning method to monitor a/f if & when you can get it the O2 sensor warm enough to get a read. |
Fuel rail sensor was the culprit
Hello all,
the fuel rail pressure sensor that was recommended was the culprit. running like a top again! Thank you so much for the help. Hopefully this will serve someone else when that problem arises for them. |
| All times are GMT -5. The time now is 06:42 AM. |
