testing back in 2002 that was the ground-work for our 2.0 turbo LNF
http://www.superstreetonline.com/how...ecotec-engine/
"The request was for 800 hp in four months in an engine that would live for 20-40 drag runs," says Stephen Bothwell, who came in from the cold to lead GM's Ecotec Drag Engine Project after 2.5 years on the road racing GM's Vortec 4200 in-line six in rally trucks plying the roads and non-roads of places like Baja, Mexico. "The attitude early on in some quarters," says Bothwell, "was people laughed at the idea of a 700 hp Ecotec. But that was then." Bothwell began by scoping out what sort of power and torque would be required to get people's attention in the "FWD Performance" world, and followed up on that with a crash program to push the envelope of an Ecotec. Hard. The GM Racing team set about to find the limits of an Ecotec the old fashioned way-by progressively blowing more nitrous through it on an engine dyno until something broke. Then repairing the engine with stronger parts (sending any damaged parts to a lab for forensic analysis), and pushing on until the next weakest link died and went to Hell. And so on. Quest for Failure: Nitrous With this in mind, GM Racing bolted a factory-stock Ecotec to an engine dyno and wired up a DFI/Accel programmable engine management system to control it via a data link connected to a laptop computer with Windows-based graphical user interface. The team then constructed a custom three-stage nitrous system designed to spray a cold fog of nitrous into the Ecotec at a single point near the throttle body, delivering additional fuel to match the oxygen-enriched air via increased pulsewidth from the stock electronic fuel injectors. GM Racing began the tuning process on a Heinen-Freud water-brake dyno using the stock intake and exhaust manifolds and a modified stock down-pipe plumbed without muffler or cat directly into the dyno cell's exhaust removal system. It turns out a well-tuned stock 10:1 2.2-liter Ecotec in the above configuration actually develops 168 crankshaft hp (which is above the factory rating of 140-150 as installed in various vehicles in the United States and Europe). At this point, the team began to pump up the volume in a rigorous series of tests while a crew stood by with fire extinguishers. Testing at a given power level concluded when the engine could survive a series of 8-10 full-power dyno "Sprints" from peak torque through maximum power in 50 rpm steps, concluding with at least six seconds at full power, for a total of at least 20 very hard seconds. GM Racing successively verified that the Ecotec survived happily at 200, 225 and 250 hp over numerous dyno pulls. However, as the Ecotec pushed through 283 hp at 4400 rpm, all four connecting rods simultaneously failed catastrophically and smashed through the side of the block. Laboratory analysis subsequently revealed a mid-beam compression fracture on all four stock powder-metal rods. All other components checked out fine. GM Racing installed a package of components you'd certainly install if you were taking the trouble to open an engine to upgrade the connecting rods: Super-duty forged Crower X-beam rods-plus 10:1 JE forged pistons with thicker top ring lands and Hastings moly ring packs. The GM Racing team installed larger fuel injectors, and continued to lean on the engine. Power advanced quickly to 350 hp, at which point the engine ran out of breathing room on the exhaust side. The ratio of Reactants (exhaust) to Products (inlet charge) is very high on a nitrous motor. GM Racing found the stock Ecotec exhaust manifold became sufficiently restrictive above 350-hp that injudiciously adding more nitrous could actually make less horsepower-due to dramatically decreased efficiencies in scavenging exhaust gases from the combustion chamber clearance volume. "We finally made 370-375 hp on nitrous," says Bothwell, "but the engine was really pissed off." Building the Turbo Ecotec At this point, GM Racing abandoned nitrous, built an efficient turbo Ecotec, and pushed on with the business of making power. The strategy was, make it efficient from Day One, then turn up the revs and boost. Bothwell's goal: 10,000 rpm and 800 hp. "We knew the stock crank would need replacing by 500 hp," says Bothwell. "Since we were going to need the rev capability, breathing and rod-stroke ratio of a square bore-stroke engine, we had Crower build a de-stroked forged billet 2.0-liter crankshaft and used it immediately from 350-hp." New, larger 4143 7/16-inch main studs replaced the head bolts to hold the new crank firmly in place. The GM Team designed a tube-type stainless header fabricated to optimize the collection of exhaust pulses in the correct order to minimize collisions. With plenty of boost, the GM team knew the stock scroll-type plastic intake manifold could flow sufficient air for 500 hp. Since the goal was way beyond 500 hp, they fabricated an aluminum, straight-port dry intake manifold with high-volume plenum for the turbo Ecotec. To regulate big air flow, GM Racing pilfered the throttle body from an LS1 V8. GM Racing designed the turbo system around an advanced Innovative Turbo turbocharger with plenty of parts available to upgrade and tweak performance as required, plus a huge wastegate and pulse-modulated electronic controller. The GM team fabricated a gigantic custom air-water intercooler that could be cooled continuously on the dyno with tap water or with a dry-ice heat-sink at the track. GM Racing subcontractor Shaver Specialties dramatically upgraded the Ecotec head with significant porting and maximum size lightweight stainless-steel valves. Current SS flow-bench data shows the ported head capable of flowing 272 cfm intake air at 0.450 lift and 175-207 cfm exhaust. With valve seals removed to prevent high-lift collisions with the retainers, Crower cams provide total intake lift and duration of .46482 inches and 221.4 degrees duration, total exhaust lift and duration of .46737 inches and 221.3 degrees. Shaver employed a proprietary GM Racing solution to forestall valve float problems at high-rpm and boost (with an eventual goal of 10,000 rpm redline, GM Racing decided to delete the Ecotec balance shafts). By this time, the Turbo Ecotec powerplant had grown significantly in width. The GM Team decided to rotate it forward by 33 degrees. This would help deal with multi-G effects on oil drain-back and dramatically reduce the difficulty of packing it in a racecar. GM Racing converted the turbo Ecotec to a multi-stage dry-sump oil system designed to reduce crankcase windage and thus increase power by scavenging oil and crankcase gases directly from the cylinder head and oil pan into a high-volume external tank. From the tank, a separate pump stage would provide superior low-temperate, high-pressure lubrication with reduced aeration directly to the short block, head and turbocharger. The GM team built a narrow, low-volume, forward-biased V-shaped oil pan that funneled return oil to dual dry-sump scavenge pickups. They opened up windows in the girdle of the "Slant-Four" to prevent oil from puddling at a relocated low point and killing horsepower by interfering with the crank at high rpm. Quest for Failure: Boost The new turbo Ecotec immediately cranked out 350 hp at 7000 rpm on 2 psi boost, and rapidly closed in on 450 hp with zero failures. "Our tuning strategy," says Bothwell. "Was to start rich with a computer-generated air-fuel map and sneak up on rich-best torque." The new turbo Ecotec was definitely responsive: GM Racing set idle at 1800 rpm, and if you punched it quick, the unloaded engine would blow completely through the 10K rev-limiter in less than a tenth of a second. The team expected an Ecotec-powered drag car to launch at 8000 rpm and run all the way through the gears in the quarter mile, so they cared mainly about the 5-10K rpm range. In this range, GM Racing wanted the turbocharger to achieve any specified level of "full boost" nearly 100-percent of the time. As testing continued, GM Racing monitored EGT and exhaust gas oxygen on all four cylinders. Full-power target EGT was 1,230-degrees F, and would never exceed 1,350-degrees. The team continuously logged all sensor and actuator data throughout the power quest. The routine was, run the dyno manually at an array of "breakpoints" of speed, loading and boost, holding the engine steady at each point to tweak various parameters that define optimal rich/best torque-using EGT and wide-range O2 data, fuel-rail pressure, torque and power read-outs, a remote-control electronic boost controller and a laptop computer to recalibrate injection pulsewidth and spark advance. Throughout turbo Ecotec dyno testing, GM Racing chilled the air-water intercooler with fresh tap water. At high levels of boost, pressurized air would enter the cooler at 200 degrees, leave at 105-110 degrees, with some creep due to packaging compromises and negligible pressure-drop. At the track, a dry ice heat-sink would reduce intake air exiting the cooler to 60-70 degrees. At 450 hp and 8 psi boost, the GM team began blowing head gaskets. One theory was that core-shifting in the block was causing the gasket to fail (because some Honda motors have this problem). "I didn't buy it," says Bothwell. "But we tried converting the Ecotec block to a solid deck. This, unfortunately, just wasted time and destroyed some blocks, probably due to thermal-expansion issues." |
The GM team decided the head was flexing. Returning to a stock-deck Ecotec block, they switched to high-strength H11 head studs. This restricted the head gasket leakage and failure exclusively to outboard sections of the fire ring at either end of the head on cylinders one and four. The GM team solved this problem by reinforcing the two problem areas with twin studs that threaded through bores machined into the upper structure of the head and jammed against the outboard fire-ring areas of the head next to cylinders one and four.
The engine now happily made 500 hp-and ran smack into the outer limits of stock coil-on-plug performance. Integral microprocessors will not allow the stock coils to energize and fire in the presence of excessive voltage. Short-term solution: GMR converted to a cam-driven distributor ignition with industrial-strength super coil. Unfortunately, as power climbed toward 600, the entire block-head interface began leaking from the extreme combustion pressures. The GM team pressed stainless O-rings into machined grooves in the head, machined receiver grooves in the block and installed a soft copper head gasket. Problem solved. At 600 hp, the extreme power and high engine speeds began distorting and flexing the aftermarket super-duty 4350 wrist pins. Left unattended, this would eventually tear out the pin towers below the wrist pins. In this same power range, the Ecotec's ring packs began failing. GM Racing opened the wrist-pin bores in the pistons by .003-inch and installed thicker H11 wrist pins with thicker walls. The team simultaneously migrated from the 1.0- x 1.0- x 3.0-inch aftermarket rings to Total Seal 1.5- x 1.5- x 4.0-inch ring packs. The Ecotec was now finally reliable to 650 hp at 19 psi of boost-a relatively low level of boost, indicating outstanding volumetric efficiency. The GM team verified acceptable stress on all parts and lowered oil pressure to 85 psi after concluding that higher pump settings simply robbed horsepower and excessively aerated the oil. The Push for 800 Horsepower Consider this: 800 hp is a lot. On a 122 cubic-inch motor with 750 hp-three-quarters of a thousand-you're basically dealing with 6.14 hp per cubic inch. Pressures and stresses of all kinds-thermal and mechanical loading across the board-escalate to extreme levels. A Chevrolet 5.7-liter LS1 V8 with this much specific power (horsepower per cubic inch) would be making 2,137 hp. GM Racing encountered a whole new world of problems between 650 and 800 hp on the Ecotec. Ring packs that worked fine at 650 hp failed to seal with acceptable blow-by as power approached 700. Pistons scuffed on cylinders, rod bearings began to go away. The ability to fire plugs through a 6 hp-per-cube mixture density required a radically powerful spark. Anti-detonation countermeasures of the highest order became crucial. GM Racing milled down the Ecotec plug bosses to accommodate a range of plug heat ranges. The super-modified Ecotec was able to achieve a reliable 750 hp on 24 psi of boost at 9000 rpm with 10:1 compression and an unspecified fuel with extremely high octane and excellent heat of vaporization characteristics. But as Bothwell's team pushed power beyond the 750-plus range, GM Racing began to encounter such extreme cylinder pressures and thermal expansion that the thin-wall stock cylinder sleeves and support structure began to warp and go out of round, split. Cylinder-piston scuffing became a problem. As of this writing, the team has developed a promising new "Super-Turbo" Ecotec, built in a process where a GMR machinist entirely removes the stock sleeves and aluminum cylinder support structure/core, pressing thick, custom-built bottom-flanged steel sleeves into receiver bores machined directly into the floor of the water jacket. GMR reinforces the new extra-thick full-floating sleeves with a pool of epoxy that effectively raises the floor of the water jacket to surround the base of the cylinders. As an anti-scuff countermeasure, GM Racing increased the cylinder bore clearance in the Super-Turbo engine by 0.001-inch, and shot-peened the piston skirts to help retain oil. Analysis It's amazing that any components whatsoever designed for a stock 140-hp 2.2-liter Ecotec would survive on an extreme powerplant making more than six times the power. However, the stock Ecotec block and main/girdle structure did survive to 750 hp, as did the stock sleeves. The stock main bearings survived. The stock stamped roller finger-followers were effective to at least 9700 rpm, as were the hydraulic lifters. The oil delivery passages remained stock to 800 hp. The stock chains, guides, tensioners and water pump worked well all the way to heaven. The stock head survived with minor strengthening and massive breathing modifications. Many other components were good for two to four times stock power (see chart). GM Powertrain engineers designed a base engine with many stock components that were above and beyond what was needed for stock performance. "The crank support structure of the Ecotec is unbelievably strong," says Bothwell. "We detected no core shifting under the most extreme conditions." The engine-fuel combination turned out to be extremely knock-resistant. The Ecotec combustion chamber is efficient, with excellent tumble and high flame speed, and the engine was able to run 10:1 compression without knock at boost pressures as high as 36 psi at 21 degrees spark advance. In a vehicle, the on-board computer is aware of which gear is in use and varies maximum boost accordingly to avoid detonation and traction problems. From the excellent power-boost ratio of 750 hp at 24 psi, one can infer that careful turbo selection, camshaft selection and timing, good intercooling and carefully considered turbo system geometry result in a happy situation in which inlet manifold pressure exceeds backpressure in a happy phenomenon called crossover, where horsepower really skyrockets. Turbo configuration and size would change three times during the tuning process. The highest-flow turbo is currently capable of delivering 40 psi boost at very high power levels. The largest Innovative wastegate is unable to divert enough exhaust to keep boost from creeping to a minimum of 15 psi when heavily loaded on the dyno, though this is not a problem on the track. What is the Ecotec's final frontier? So far, unknown; but we'll be looking to the track in 2002 for the answers to that question. Ecotec Building Blocks The Ecotec's outstanding feature to performance enthusiasts will undoubtedly be its impressive strength. GM Racing dyno tests confirm an otherwise bone-stock Ecotec is capable of a reliable 350 hp with forged rods and pistons (and a bunch of nitrous or boost). Add a billet crank, minor head reinforcing, and cylinder O-rings, and breathed-on turbo Ecotecs will live to race many times at 650 hp. Re-sleeve the block and 800-1,000 usable horsepower appears feasible with the right fuel. The lightweight, low-friction Ecotec powerplant is built around a strong and compact 86mm-bore block manufactured with the lost-foam casting technique (they pack sulfur casting sand around Styrofoam molds shellacked with ceramic, then inject molten aluminum into the foam, which is vaporized into recoverable gas as the metal replaces it.) Flanged, thin-wall iron cylinder sleeves press-fit into a semi-floating aluminum support structure/core. The Ecotec block is supported by a massive die-cast aluminum girdle/main cap assembly and structural oil pan designed to impart rigidity for improved longevity and low noise, vibration, and harshness (NVH). The main-cap structures are each supported with six fasteners. Extra-thick main bearings resist the differential thermal expansion of the nodular-iron aerodynamic crank and aluminum block. GM casts all Ecotec blocks with passages for piston-cooling jets and an oil cooler usable for potential high-output turbocharged applications. The fully-boxed block requires no windage tray, even on GM Racing 650+hp drag motors. An auxiliary chain drives the water pump and optional balance shafts from the crank. To avoid potential hot spots, pressure-cast non-squish dished 9.5:1 pistons negate the need for any valve pockets; for high compression applications, flat-topping the pistons produces a 10:1 compression ratio. The top ring is a symmetrical, barrel-faced moly-coated design that fits in an anodized groove below a super-thin 3mm top ring land for low crevasse volume and reduced emissions. The pistons deliver power through full-floating pins and powder-metal or forged connecting rods. GM designed the twin-cam head for low-friction hydraulic roller finger-followers, proven effective and reliable to 9,500 rpm in GM Racing's Ecotec drag engine program. Head fastener placement permits cylinder head R&R without cam removal. The cams are driven directly off the crank by a chain, with the design protected for possible future variable cam phasing. The finger-follower design permits a lightweight narrow profile and reduced valve angles of 18 and 16 degrees. GM engineers used the port tumble ratio to balance full and part-load combustion without need for variable-length intake runners. Port injectors mount in the head itself for optimal spray geometry, and the design is also protected for possible future direct injection-gasoline. Ecotec engine management uses a speed-density port-EFI design with direct coil-on plug ignition. An integral compression-sense ignition module eliminates the need for a cam-position sensor. |
Great read. Thanks.
Interesting, I eagerly await the next episode!
So in the movie, who plays Stephen Bothwell??
Tom Cruise, naw to cliche! Tom Hanks, hmm maybe but then Ron Howard would have to direct it. How about that kid from The Good Doctor, and Bates Motel?? Really this story needs to be told, there are millions if these Ecotec engines churning along the mundane roads of life, ignored for the power hidden under their valve covers, and a healthy bank account! A great read there, thank you for taking the time to type it all out. I’m gonna print it off and read it old school , in front of the fireplace , snuggled in my lazy boy recliner leather chair, with a brandy or scotch to sip. |
Originally Posted by Oldblue
(Post 834255)
Originally Posted by Trex08
(Post 834264)
Lol, I think that was copy and pasted, took long enough to read, I can't image typing that out, but hey, maybe he's old school.
Outstanding content! Milquetoast babies can go and die in a fire.
The quantity of the info outweighs the presentation. Big deal!!!! |
Shouldnt all you turbo guys really be thanking Granpa Gregg with his 2006 2.4 LE5, the first iteration on the reinforced Gen II block, forged internals, laying the groundwork for what would become the LNF? Bow down, all ye forced induction, to your N/A maker!
https://cimg5.ibsrv.net/gimg/www.che...3508491124.jpg |
