Transformers Center caps?
That's true. But I think his first concern was that of center caps fitting on HHR wheels. When that seemed no go it appeared having Camaro rims working so that the transformer cap could fit. Yeah, there's no way the 20's or 21's could work as you said because of widths and offsets. But the 18's, now that's a different story. I could probably machine the correct opening on the HHR wheel to allow the transformer cap to snap in. As easy as that sounds, it's easier and less work to change the bolt pattern in the camaro wheels.
You had better also explain how to properly change bolt patterns on an HHR. You know that one is coming too.
Maybe I'm missing something here with going from center caps to rims, but my post from the first page of this thread has a link to a company touting the center caps for Cobalts... Wouldn't that be the same fit for the HHR center cap + the measurements are on that link.
