Turning issue '09 SS Turbo
Old Feb 15, 2021 | 10:37 AM
turboss2009's Avatar
I was pulling car out of garage the other day and as soon as I made the first turn the steering wheel would not recover I had to manually steer to straight. No difficulty steering, no codes, steers otherwise great, never did this before. Any clues? any help would be greatly appreciated. thank you turboss2009
Old Feb 15, 2021 | 11:07 AM
Sounds like somebody should inspect the steering gear. Something is broken/worn out/etc.
Old Feb 15, 2021 | 11:28 AM
Guess I'm misunderstanding the description of the issue. On mine, if you're stationary or barely moving, you turn the wheel and it pretty much stays in that position until you turn the steering wheel back.
The wheels have to be rolling to allow the steering to self "center" up.
Now if you're saying it got stiff/stuck and you had to turn the steering back, then like Donbrew stated check for worn parts.
FYI . What's the mileage on this SS and any steering component repairs been done ?
Old Feb 15, 2021 | 11:45 AM
Yes while moving say making a right hand while moving, turn normally and steering wheel would kind of correct to straight as most with little assistance. Now if you do not steer out of the right(or left) manually it will continue. Car has 102K pampered miles and has been a PIA since i owned it, good thing i can work on cars..lol I just don't want to trouble shoot with the gazillian sensors etc and motors. Thought this might be a common thing. Like i said otherwise car drives great no noise, shackes, rattles, whining??? Thanks for the responses
Old Feb 15, 2021 | 02:58 PM
You want tons of sensors get a Ford. And techs with even less knowledge about them than GM
Old Feb 15, 2021 | 04:12 PM
Has anyone w/HHR SS had an intermediate shaft failure on their SS. Mine at slow rolling turn stopped going back to center just trying to weed it down to a part. No noise, codes, nothing. just all of a sudden. Has approx. 110K easy miles. I understand removed from inside the car?? Thanks for any help or info
Old Feb 15, 2021 | 05:09 PM
I deleted your duplicate thread, let's keep it here in this one thread.
Old Feb 16, 2021 | 09:57 AM
This could be a steering rack issue or the intermediate steering shaft. Does the joint and yoke appear rusty under the brake booster , out in front of the firewall?
Old Feb 16, 2021 | 11:28 AM
"could be" lots of things
A few:
tires
tie rods
ball joints
rack
intermediate shaft
EPS motor
EPS module
Starting point would be get up in the air for a visual/mechanical inspection.
Kaleb96
Sep 2, 2019 06:17 AM
SuKi
Sep 27, 2017 05:31 PM
Supafly94
Aug 4, 2017 02:36 PM
Marcruger
Jun 30, 2010 10:27 PM
mr_hhr
Jul 3, 2009 03:30 PM
