What does a BOV do?
What does a BOV do?
I know some of you guys are probably rolling your eyes on this one, but I am trying to learn, so please be patient with me as this is only my 2ND turbo engine.
How does a BOV (Blow Off Valve) work, and what does it gain?
I love my retro rocket and would like to get the most "bolt-on" power I can get. I am considering an Exhaust, possibly a CAI (Cold Air Intake)/Air filter, inter cooler plumbing and a future tune to get the most out of my aftermarket parts. I want to add all of the bolt-on parts before I consider a tune, thus my question on the BOV.
I spelled out some of the acronyms as I know that others like myself are not totally aware of all of them.
Thanks in advance,
Thanks in advance,
Here's my brief explanation of a BOV. When you build alot of boost and close the throttle abruptly, such as when you shift (without using NLS) the turbo is spinning very fast and pushing alot of air through the engine. Then the throttle closes, and the still spinning turbo can build an enormous amount of boost in the piping due to the inertia of the turbine wheels. It can build so much pressure, in fact, that it can stop the turbine wheels almost instantaneously and damage the turbo. Thus, the blowoff valve is there to release that excess pressure and, as stated previously, keep you from grenading the turbo. A BOV is a supporting mod that allows you to run more boost, and just like many other mods in a turbo system, will not add power in and of itself.
Also, in a vent to atmosphere setup, a BOV requires tuning because it will cause the air fuel ratio to momentarily change drastically when the blow off occurs.
So, it sounds like it may be something that helps the life of the turbo, especially if boost is increased more than stock.
After reading the link XXL sent (thanks XXL), it sounds like a better solution is a compressor bypass valve (CBV) which vents back into the intake after the MAF sensor. This helps the ECU do a better job of adjusting mixture.
Why don't I ever hear about CBVs? Too expensive due to the extra piping required? Not as "cool" due to lack of the extra sound?
