What you think of these seats in the SS?
2 Attachment(s)
They are corbeau Cr1 and looking to replace the SS seat with these seats.
Attachment 25858 Here my stockers Attachment 25859 I was think of stitching SS on them. What you guys think? |
They are sort of sweet Rob, but I am 95% positive that our seats are made by Recaro for GM. I know Recaro won a contract about 5-6 years ago to build all specialty seats for GM Performance division.
How much lighter are they.
On my streetrod/race car I added a 250 pound roll cage so I started looking to pull weight The power seats I pulled out weighed 67# each to my surprise The fiberglass buckets that went in weighed about 15 .Each 100 pounds out is about a tenth in the quarter. Just saying . I like tje black with red trim in the red or black hhrs myself |
1 Attachment(s)
They are 27lbs and I could go with the forza which is 19lbs.
Attachment 25857 |
They are sharp Rob, most defienetly.
:twothumbs: |
Is the 27# & 19# with tracks and mounts ? What is total installed wt. Can you use the stock seat belts ? Just some of things I have run into when looking for less wt. with seats.
I like those seats, they look a little more form fitting than the stock. Seats are last on my list, but I would like to replace them some day. I can not find any manufacturer that makes brackets for the HHR SS.
Sometimes you just have to make your own. How much should i sell stock seats for?
I would ( and plan to ) switch to Recaros. The Corbeaus I have are okay, but pale in comparison to the fit, finish, and feel of the Style toplines I sat my narrow butt in. I tried reclining as well as fixed back from the Sparco line, but the Recaros feel a lot better for only a little more than Sparco. You will have to make your own brackets, but you already know that since you've seen my thread on the seat change. I sold my stock performance seats for $750 if I remember correctly.
Originally Posted by oneton
(Post 653726)
I reused the stock seatbelts, and even installed the passenger seat air bladder in the new seats (my wife hates that the car tells on her when she doesn't belt up quick enough). I went with double locking tracks and fabbed up my own brackets. I built in some room for adjustments, and tweaked things 5 or 6 times to get the right seating position. |
| All times are GMT -5. The time now is 09:40 AM. |
