will this size rim work for me????
will this work??? i found some 18x8 wheels with a nice lip. the offset is +45. how will this look on the car??? not going to put them on till my coilovers get here. going with a 225/40 tire.
It depends on how much you lower it. I don't think you'll have a lot of extra room either way. The back should be ok, but you might rub a little on the front.
not sure if this will help, but here is a drawing i did to show the diff between stock wheels and g6 wheels. the g6 wheels are a little wider
https://www.chevyhhr.net/gallery/fil...eeloffsets.JPG |
Try this, OEM tire and rim then in 2nd row put in the new ones.
http://www.rims-n-tires.com/rt_specs.jsp |
| All times are GMT -5. The time now is 08:10 AM. |
