ZZ Performance or other tuner?
I've had my HHR SS for a few years now (85,000 miles) and I have always wanted to do some mods to it but never have gotten around to them. I've done some reading up on various tuner companies and options and it seems that ZZ Performance has a lot available for our LNF engine.
So my question is... what is your take on ZZ Performance and what they have available and which mods are best to start with from a stock HHR SS. Only thing I have right now is a K&N drop in. Also, what is your opinion on the GM available turbo upgrade kit for $700 plus install as compared to a tuner option. Thanks in advance for anyone's help |
I'm guessing that nobody has any experience with ZZ Performance regarding their HHR SS?
I was hoping someone would chime in, but alas, nobody.
Don't remember too many members here that went with the ZZP tune. Those that did, it was a while back. They may not be active here or may not have their SS anymore.
I've had the GMTU for 8 or 9 years. Happy with it. No issues. As far as getting the GM turbo upgrade now, I couldn't recommend it. It has to be GM dealer installed and reflashed by them. That is the problem. The dealers are not going to be familiar with it because it's a 12 year old, outdated option. Plus, if you needed any tech support from GM with it, you probably couldn't get any. (just my 2 cents) |
(Post 902944)
I didn't want to say anything because I am having an issue with the car.
New LDK/LHU, upgraded fuel rail, Bosch TMAP sensors, all from ZZP. I got the ECM tune also from them based on these upgrades, and everything else stock. I have been getting a P0101. It is occurring more and more frequently, sometimes several times on the way to/from work. I don't think it's the tune. I suspect that there is something wrong at the lower TMAP sensor. It was awesome for awhile, and I hope it will be again once I find the problem. Working 6/12s, can't find any time. |
I had my hhr dyno tuned by zzp. If you are choosing between those two, definitely go with zzp. Solid company that specializes on these engines.
(Post 902938)
Originally Posted by RBodeman
(Post 902974)
I was kinda thinking that since the GMTU has been around for so long, that it would be a good option. You know...worked out the kinks kinda thing. The physical install does not sound all the complicated and wouldnt the reflash be just the dealer plugging in their system and running something. I don know...I might be being naive here.
(Disclaimer: Yes I know there are some individuals that have those GMTU files. They may sell them or even give them to you free. I'm just not in support of using pirated software like that ) |
(Post 902974)
I did have one issue. I hauled my car out west in my trailer, behind my RV. I made the mistake of unloading it at high altitude in West Yellowstone and not cycling it a couple of times to test the ambient air pressure / elevation... I passed a few cars, right after unloading it, which it did, without a problem, but then after that, it had a low rpm, high throttle miss. I changed spark plugs and it didn't cure it completely. I then gapped the plugs a bit tighter and that cured it. I will probably put some colder plugs in it the next time I change the oil. Now that the weather is cooling down here in north GA, it is even more fun to drive 😁. Knowing the kit would not have affected my warranty, if I we're still covered, is just added piece of mind. Robert |
(Post 902981)
Yes. The physical install is very simple. The dealer does the reflash but has to get (buy) the files from GM and they are VIN based. So no. Not something the dealer has "stored" in their computer.
(Disclaimer: Yes I know there are some individuals that have those GMTU files. They may sell them or even give them to you free. I'm just not in support of using pirated software like that ) Does this sound right? |
| All times are GMT -5. The time now is 05:58 AM. |
