2010 HHR SS Adding turbo gauge to A pillar
#33
#34
Original did not require adapter
Hi...
I did the original post on this subject back in 06/15. Just wanted to mention that with parts I received, there was no adapters required. In other words, the meter plugged in directly the the dash plug with no adapter required.
Thank you, Darrell
Thank you, Darrell
#35
Turns out mine was from a Cobalt and apparently the GM engineers are real jokester *******s and made the connections different.
#36
I posted what the "book" says the connectors are. They are different part numbers but look the same to me.
Since the brand is also an after market supplier, I wonder if it might not be original equipment.
#37
Apparently, those sadistic GM engineers decided to throw me a curve ball. Seems like they basically swapped the male and female ends between the HHR and the "Balt.
One of my FB friends sent me a female piece that has three out of the four connectors and I am going to try to jury rig things using the info you shared.
Not terribly optimistic about my chances, but I will try before admitting defeat and getting someone else to wire it for me.
#39
Maybe I'm missing something. You have a Male to Female connector plugs.
Are you saying the pins from one don't line up to the other?
Edit: The more I look at this picture there are two wires that aren't going up and down but sideways. All you have to do is take those two wires and take them out of the socket and put them in the correct slots on the connector so they go up and down.
#40
