Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
12628348 - Exhaust cam solenoid
12628347 - Intake cam solenoid
One of them was in-stock, the other was delivered the next morning to the dealer - so I gather they are a commonly available part. The code you pull down from the CEL, will tell you which solenoid needs replacing (I replaced both of them as I figured, what the heck
if I am gonna tear it apart for one, I'll replace them both).Good luck
engine and tc lite on
which solenoid is the exhaust? my code p0014 and tc light are on i used a code changer at advance auto to turn them off. i want to do the switch so they stay off. not sure which is exhaust and intake
Thanks to Whopper and all who posted on this subject. I paid the dealer to replace the first solenoid then I read all about it here and ordered the other one and fixed it myself. Car runs great and no lights so far! Thanks again for the detailed how to. It really did help.
My TC light came on yesterday and was off this morning and on again today leaving work and this time the engine light came on as well.
I know it is time for an oil change (25%), so will have the dealer have a look see for me -- it did seem to run a little rougher and felt like it "pulled" when the gears changed (have an automatic) -- I assume that is not normal. :)
I drove him home from work, 35 miles on the freeway and he seemed as smooth as ever otherwise...I've NEVER had problems in almost 3 years, so am a little concerned (at 32K now).
I'll have them check the solenoid thingy.
Thanks!
Thanks!
