Cleaning the throttlebody tomorrow, anything I need to be careful on?
Old Sep 20, 2014 | 08:36 PM
ImNewHere's Avatar
As the title says, I am cleaning the throttle body on my '06 2.4 tomorrow, so I wanted to know if there is anything I need to be careful with or on from those who have done this before. Thanks.
Old Sep 20, 2014 | 08:41 PM
No silicone products, no MEK, no acetone, ignition off. To disconnect pop the gray clip out a stop then use a small screwdriver to push the black tab down.
Old Sep 21, 2014 | 07:48 AM
Do not use carb cleaner! Do not push open the TB butterfly plate! Use a product specifically for cleaning the throttlebody!
Old Sep 21, 2014 | 12:43 PM
ImNewHere's Avatar
I just did it. I removed the air filter housing, then air intake connector from the air filter to the throttle body and the hose from the valve cover, then I removed the connector, then the throttle body. It was dirty. Very, very dirty. I use a seafoam spray that is specified for that (and as a lubricant) and got it all nice and clean, then put it all back together. I just idled it for 10 minutes. It has been a while since the idle was that smooth. Now I am about to do a trip into town. Ohh, no CEL on at all. I think after 172k miles my car was ready for this.
Old Sep 21, 2014 | 01:41 PM
hhr06NJ's Avatar
GOOD JOB!
mine was stalling at at idle and then when decelerating while turning a corner at 80,000 mi. cleaned TB and ran perfectly! I think should be done when changing plugs.
Old Sep 21, 2014 | 01:48 PM
Good job!
Old Sep 21, 2014 | 02:47 PM
ImNewHere's Avatar
I drove it on a 45 mile round trip and it ran great with no CEL, though I didn't see a change in fuel economy. Think I should reset the ECM?
Old Sep 21, 2014 | 03:57 PM
hhr06NJ's Avatar
HOW do you reset the ECM?
Old Sep 21, 2014 | 04:23 PM
Disconnect the battery.
Radco
Nov 11, 2012 02:22 PM
probablecause
Feb 8, 2010 06:25 PM
johnbegone
Mid Central
27
Feb 6, 2008 06:43 PM
britinamerica
Oct 1, 2007 07:54 AM
JOEK86
May 8, 2006 11:02 AM
