EVAP Canister Vent Solenoid Valve Replacement
Old Sep 9, 2019 | 05:58 PM
  #51
That one in your link shows a seal of some sort . In the tube on the canister side
Old Sep 9, 2019 | 09:41 PM
  #52
Lethal Tendencies's Avatar
Originally Posted by donbrew
Mine had a soft O-ring that was in the canister hole.
Thats what I am wondering, If the seal is in the canister hole, because when I took out the old solenoid it looked the same as the new one
Old Sep 9, 2019 | 10:19 PM
  #53
Others have gone to the O-ring store and bought one that fit around the snout.
Old Sep 10, 2019 | 07:59 AM
  #54
I will try that. thanks
Old Oct 5, 2020 | 09:19 PM
  #55
miktel53's Avatar
Is there a trick to disconnect vent tube I've push the white tabs in no results thought may not be pushing far enough so had small pliers to push further still won't come apart any help out there
Old Oct 6, 2020 | 06:56 PM
  #56
Try a spray of WD 40 to blast out any crude built up in there.
Old Mar 30, 2021 | 11:05 PM
  #57
Venus Marie's Avatar
Originally Posted by DaGrinch
I guess my biggest question to all this, since my '09 2.4 is throwing the P0449 code.... Did you TRY anything else BEFORE you replaced the EVAP solenoid, or did you just replace that?
I've been told the P0449 code could be anything from a bad gasket on the fuel cap to broken/cut hose running to the canister to the solenoid itself.
I realize this is an old thread, but hopefully a couple more answers can be answered before I spring for the solenoid - agreed, it's not expensive if DIY, but replacing the gas cap is easier. And I'm all about easy at this stage in life!
Larry - DaGrinch
I tried everything it said to try and nothing worked... Took it to my daughter mechanic and he replaced the canister vent solenoid...and there you have it... All fixed
Old Mar 31, 2021 | 06:27 AM
  #58
Guess you didn’t try everything, glad it’s fixed, Welcome to the site!
Old Mar 31, 2024 | 01:03 AM
  #59
Vampyreblood's Avatar
Originally Posted by TiggersHHR
If anyone has their HHR come up with a P0449 code don't take it to the dealer to fix.
It is a quick and easy fix, only cost me $30 in parts and my time.
Dealer wanted to charge me $180 to do the job. Said that GM changed the plus style on solenoid and I had to buy a jumper wire as well as solenoid.
Went to my local PepBoys, bought a replacement solenoid, and an Innova Equus 3030 diagnostic tool so I could erase code. Bonus is I can use the diagnostic tool on almost all cars 1996 and newer. Solenoid is made by BWD (part #CPV43), not an ACDelco but still made in the USA. It has the new GM style plug, but it comes with the jumper wire included.
1) back your HHR up onto a set of ramps - this makes it easier to get to the solenoid.
2) disconnect the wire plug from the solenoid (it is on the back side).
3) gently push retaining clip back and slid solenoid off of charcoal canister.
4) push in on both retaining clips on vent hose and slid it off of solenoid.
5) take rubber seal off of old solenoid and place it on new solenoid.
6) gently slid new solenoid back onto charcoal canister until retaining clip clicks.
7) slid vent hose back onto solenoid until retaining clips click.
8) gently tug on solenoid and vent hose to make sure everything is secure.
9) connect new plug to solenoid and clip old style end to rear cross member.
10) connect old plug to wire jumper.
11) connect diagnostic tool to vehicle, clear code, and remove diagnostic tool.
12) start vehicle, verify engine light does not come back on, and drive it off ramps.
Picture below is with new solenoid installed. You can see the "red" jumper wire connection attached to cross member.
I had the code pop and I cleared it a few times and new gas cap and code hasn't came back, but today my gas cap wouldn't come off. Went to advance auto where I got the cap, guy they eventually got it off and replaced with a new cap that so far I can get off. After research I saw it said this part can cause that, so I have this part with new connector ordered from Rock Auto. So my question is....should that be what caused the possible vacuum lock on the gas cap? Or could the cannister itself or the purge solenoid on the engine cause it too?
Old Mar 31, 2024 | 06:47 AM
  #60
It’s plausible. But I don’t think so.
