Shifter stuck in Park fix
Technical Moderator
From youtube. If your key will release, but the shifter is stuck in park. He skips over the important part: a shot of WD40 or your favorite aerosol lube/cleaner on the solenoid lever that he is pointing at.
Technical Moderator
https://www.chevyhhr.net/forums/gm-r...14632-a-52498/
There was a recall issued for 2009 models, BUT it was recalled (cancelled).
