How to repair worn clutch pedal arm
Very helpful. Im having an issue with the spring, my original post: https://www.chevyhhr.net/forums/prob...e4/#post888098
Ill have to buy some JBWeld, that stuff sounds amazing, and you did a really good job using it to fix that issue. I noticed mine is worn as well, so this will help. But i'll have to buy the spring, as it probably should be replaced as well.
Thanks again, DeVoiD
Yes get the spring kit, it sounds like the center bushing on yours is completely gone?
It's pretty easy to work with, a 2-part epoxy. I was pleased that, as the pics show, the repair was still good 2 1/2 years later. I haven't looked at it since.
