Originally Posted by donbrew
(Post 760560)
T-stat is stuck open. 192 F is normal. I bet your A/C doesn't work.
Pop "p0128" into the search box or google to get the why. It is well covered and frankly gets boring to me.
(Post 760563)
FWIW, when I was about two blocks from the auto parts store, the temp gauge suddenly started working again and the temp climbed steadily from ~170° to the 195° I'm used to. Bought the new t-stat anyway and will replace tomorrow (after the car has cooled down). Sure acts like a stuck t-stat that loosened up again, so this should fix it. Thanks again! |
Thats not what I meant, this tiny keyboard is my problem.
Originally Posted by brossow
(Post 760569)
Sorry, didn't mean to imply I was asking for an explanation -- just saying I was surprised is all. :smile:
FWIW, when I was about two blocks from the auto parts store, the temp gauge suddenly started working again and the temp climbed steadily from ~170° to the 195° I'm used to. Bought the new t-stat anyway and will replace tomorrow (after the car has cooled down). Sure acts like a stuck t-stat that loosened up again, so this should fix it. Thanks again! Let us know how the replacement goes, and if it resolves your problems. |
Problem solved. Not quite at easy as an old small-block Chevy, but not terrible by any means. Once I got the old one out, it was obvious that it needed to be replaced (old one on the left, replacement on the right):
https://www.chevyhhr.net/gallery/fil.../4/_115486.jpg https://www.chevyhhr.net/gallery/fil...011_174359.jpg Took it for a short drive and it got up to temp right away. Thanks again for the advice! :thumb: |
Just curious, what brand? The one that came in my 2011 does not have a large inner rubber seal, you can barely see it, it's not big enough to make a problem.
Originally Posted by vtfb68
(Post 589804)
Mine went out last month @ 56,000 miles, It cost me $0.00 becuse of the 100,000 mile powertrain coverage that we all have. I sure hope everybody posting were out of warranty at the time of change. Love those warranties!!
VT |
Originally Posted by jer1041
(Post 768104)
The thermostat is covered by the 100,00 mile warrantee? Even if the vehicle (I purchased new in 2006) is 9 years old? It has 50,000 miles on it.
Hello guys & gals,
I used this thread back in July 2014 to replace the thermostat. About 8000 miles later getting the p0128 code. I picked the thermostat at Adv Auto Parts and it wasn't the ACDelco brand. I did check my coolant levels and seem fine. Anyone else have this issue? -Also can I damage the car if I keep on driving it like this? Thanks in advance. |
