Progress Tech Sway Bar Install...
Old 05-12-2006, 08:59 PM
SoCalHHR's Avatar
Here's a complete how-to for installing the Progress Technology Rear Anti-Sway Bar for the HHR:
Rear Sway Bar Install
Enjoy!
SoCalHHR is offline
Old 05-12-2006, 09:04 PM
SindyDix's Avatar
... perhaps that is the largerst thing(s) you have hauled in your (lowered) HHR!
...and a previous thread topic I may add!
SindyDix is offline
Old 05-12-2006, 09:15 PM
SoCalHHR's Avatar
Nope, not even close! I once hauled 3 tall steel storage racks (in boxes), two 3 drawer base cabinets, and a 78-inch door - all at ONCE in my HHR!
Oh, and with the sub box inside, hooked up and playing!
SoCalHHR is offline
Old 05-22-2007, 07:40 AM
Goose's Avatar
Year old thread but thanks for posting this way back when!
Goose
Goose is offline
Old 06-09-2007, 09:55 AM
courthousedeb's Avatar
Was looking thru all my many HHR photos and found the pics that Mike from SoCalHHR's had for install.
Thought I'd share them with those of you who would like to see them and post my version of installing the sway bar.
Plus the pics are here on the site, just in case Mike's page ever disappears for some reason.
This is what your package should look like if's it's a Progress Tech.
Very large heavy box with sway bar and a bag of parts.
Mine came with instructions when I bought it from Mike.
Hardware needed to install the sway bar.
(oh lookie there...there's the directions inside that plastic bag)
Ladies will read them...guys will do the macho thing and set them aside.
Henry and I backed my car up on ramps and that made it much easier to install.
It is recommended to do it flat...
but when you are in your early 50's like us,
you don't fit under the car like you used to.
Easy part is finding the holes where the sway bar will attach.
Then slide the piece that the bolts will screw into above these holes
and line it up as best you can.
This can be a little tricky when putting the bolt and washer on,
cuz the dang thing moves.
Insert bolts and hand tighten.
Tighten the right side with torque wrench to 45 ft lbs.
Tighten the left side with torque wrench to 45 ft lbs.
You are now done...take that mean machine of yours out for a spin
and check out the difference in the ride.
Thanks go out to Mike from SoCalHHR's for the great photos and product he supplied me.
Definitely made a huge difference with body roll once it was installed.
courthousedeb is offline
Old 07-02-2007, 08:57 PM
barberpole's Avatar
thanks,it realy made a difference,
barberpole is offline
Old 07-02-2007, 09:03 PM
barberpole's Avatar
it as easy as it look to install
Old 07-02-2007, 10:36 PM
MrVette's Avatar
Great!! Now I see the how to pics after I installed mine backwards and upside-down
Just kidding, but the how to pics here sure are better than the supplied instructions!! WTG!
MrVette is offline
Old 10-28-2007, 06:37 AM
chelseahhr's Avatar
Thanks for the pictures and info. Got my sway bar installed last friday and found a significant change of performance.
Sorry for the rockies, i still cheer for them but hopes are fading
chelseahhr is offline
Old 07-27-2008, 11:17 PM
Jeda13's Avatar
Is this something I could/should do on my SS? I haven't looked underneath yet to even see if there is an anti-sway bar for mine.
My how things change, the first mod I made to my Jeep was to disconnect the anti-sway bar for offroading...
JIm
Jeda13 is offline
Quick Reply: Progress Tech Sway Bar Install...
