Rear Wiper Mod
Rear Wiper Mod
This is so easy, and when you are done, you'll be able to pull your rear wiper away from the glass, far enough to clean or change it for new, and it stays off the glass until you put it back.
The cover pulls off very easily. Remove it, look on the inside, there is a small tab that you just break off. Then put the cover back on. Here is a pic with the cover off, showing where the tab used to be.
Credit goes to SoCalHHRs, they had a how-to here, but there is no longer any value to it. The pics are gone, the links are dead, so I'm deleting it.
