Replacing the Oil Pressure Sending Unit
#31
what does it mean "1/4 pipe thread"?
I understand in standard international metric system. I remember all those stupid sizes in wrenches like 1/2 it's 12.54mm, 3/8 it's close to 10mm etc.
I'm not sure will I find it(sensor) tomorrow because I will walk to the junk yard and especially -- it's Saturday.
Also one more question about torque starter bolts - is it really just 16-18 lbs? I want to add blue thread locker - is it a good idea?
#32
ap This Size Pipe:
Use This Drill Bit:
(Closest Fractional:)
Decimal Inches:
1/8-27 NPT
Ltr.R
.3390
1/4-18 NPT
7/16"
7/16"
.4375
3/8-18 NPT
37/64"
Grab an a used oil pressure sensor, as for the bolts yes, and use the blue loctite
Use This Drill Bit:
Decimal Inches:
1/8-27 NPT
Ltr.R
.3390
1/4-18 NPT
7/16"
7/16"
.4375
3/8-18 NPT
37/64"
#33
Mine was dripping from where the plastic meets the metal. I have had this type of unit fail on other cars as well.
On my 85 it failed when the metal corroded and the plastic blew out - what a mess....
#35
- oil pressure switch - 16 lb ft
- anti-knock sensor - 18 lb ft
- reattach the connector for the anti-knock sensor, and push the red tab in to lock it in position
- install the starter with the two bolts (14mm socket) - 39 lb ft
