Replacing the Oil Pressure Sending Unit
Old Jun 16, 2018 | 10:06 AM
phrog fixer's Avatar
Well got my pressure switch and tools ready to go. Removed oil pressure switch noticed it had a crush washer on it and my new switch doesn't. Went back to Auto Zone the other two they had are missing it. The computer description say it should have it. Contacted Chevrolet dealer they say it should have it. So now I'm on hold for two hours till the dealers gets one in. I won't be a happy camper if I to put the old one back in.
Crush washer
Old Jun 16, 2018 | 02:12 PM
Are you sure it is a crush washer looks like a copper banjo fitting washer to me, maybe oil drain. Unfortunately they sell them by the bag.
My service manual does not show any sort of washer or gasket.
Old Jun 16, 2018 | 03:04 PM
Brand new from the Chevy dealer. They call it a crush washer. It is installed and done. If you do this make sure to use electrical cleaner to get the oil out of the plug.
Old Dec 6, 2018 | 10:57 AM
06REDSEDANDELIVERY's Avatar
CHECK THE PRONGS TO MAKE SURE THEY ARE NOT OUT OF ALIGNMENT - don't ask me how I know.... The plug would not go in.... I coated the threads with GM head bolt sealer because I had it.
Old Dec 6, 2018 | 01:17 PM
Good tip!!!
Old Dec 14, 2018 | 05:36 PM
  #26
Jay23's Avatar
so is it no way just tighten this sensor - anyway should I find the new one? Maybe just the washer? Not sure I'll find it so fast tomorrow - I have no car yet, motorcycle is garaged, don't want to take off starter one more time... I know if the oil was leaking from oil pan bolt on the trucks - I was replacing just a new copper washer.
Old Dec 14, 2018 | 06:36 PM
  #27
Try just the copper washer, but sometimes it will leak were the plastic meets the metal .
Old Dec 14, 2018 | 06:40 PM
  #28
Jay23's Avatar
Does somebody know what is the thread diameter on that sensor? - I had some copper washers in my toolbox.
Old Dec 14, 2018 | 06:44 PM
  #29
Looks like 1/4 pipe thread , I’ve changed one but tossed it out .
you can also use Teflon tape in the threads.
Old Dec 14, 2018 | 07:00 PM
  #30
Yes. If you're going through the trouble of pulling it out, just put a new one in. Why take any chances on an old sending unit. They don't cost much anyhow.
Better safe than sorry.
