Smoothie Door Lock Knob install
Smoothie Installation 1. Grab OEM lock knobs with pliers. (If you want to save the OEM’s, use something to protect them.) Twist them to break the seal, they are not threaded, and pull off. 2. Test fit the Smoothie Lock Knobs. (I feel the rods do not need to be cut but this is merely personal preference. a. Uncut rods: 3. Use a clear adhesive on the rod and in the lock knob. a. I recommend this product. https://www.chevyhhr.net/gallery/fil.../5/1/80050.jpg 4. Let dry for a few hours and you’re good to go!
good mod, and much needed lol. can u see the rod after u break the old ones off.I can't believe that they are just silconed on from the factory like that.
Originally Posted by gren25
(Post 182076)
BTW, these can be purchased at www.thehhrstore.com ;) |
I took about a quarter inch of rod off mine and when locked, mine sit flush with the door panel.
Originally Posted by Memphis_HHR
(Post 182100)
I found that just switching them out was enough to stop the elbow jabbing. But everyone is different and that's great! |
Mine sit a bit taller than the ones shown in the pics, but are much better than the stock ones.
I'm still debating whether to cut a bit off of the rod or not. If I do, I'll probably only take 1/8" off. One of them is fairly tight and "chirps" when the doors unlock. |
Just ordered mine!!! Looks good!! JR
Originally Posted by Black Rose
(Post 182153)
I'm still debating whether to cut a bit off of the rod or not. If I do, I'll probably only take 1/8" off. One of them is fairly tight and "chirps" when the doors unlock. I actually did mine at stoplights on my way to the office ;) |
bump
Thanks for the bump. I needed that! :)
