Chevy HHR Network
-   "How To" Tutorial Library (https://www.chevyhhr.net/forums/how-tutorial-library-21/)
-   -   Spring Install (Dial-up, enter at your own risk) (https://www.chevyhhr.net/forums/how-tutorial-library-21/spring-install-dial-up-enter-your-own-risk-986/)
1Panel2NV Sep 29, 2007 09:04 AM
Originally Posted by stick (Post 189524)
Only thing I want to add is the two bolts running through the spindle and strut can be driven out with a air chisel if you own one. Worked great for mine--out in two seconds--and didn't mess up any threads by leaving the nut down at the end of the bolt!
+1 :thumb:
Air chisel = better than hammer ;)
The Curly 1 Sep 16, 2008 08:18 PM
Thanks for the info
Sat. the Goldline springs so on with new wheels. Curly
The Curly 1 Sep 20, 2008 09:31 PM
Thanks for the info
2 Attachment(s)
NG8650, How do you like the ride now?
I put the Goldline springs on mine and Solstice wheels and I love it. The car rides soo much better smoother and corners better.
Attachment 35862
Attachment 35863
Thanks, Curly
Rcflyboy Oct 5, 2008 09:34 AM
Just an F.Y.I. for anyone adding lowering springs. An Air Hammer makes quick work of the two lower strut bolts. Just put the nut on backwards (Helps stop the hammer bit from wondering off the bolt), screw it down just shy of the end of the bolt and put the hammer bit on the bolt and hammer off. Takes about 2 seconds.
Pay attention to the orientation of the top spring cap when you remove it from the old spring. It is angled on one side. Don't do what I did. When I went to reinstall the new spring I put it on backward. I didn't figure that out till I did the other side. So I was awarded with the opportunity to do that side again.
DLVRNIT Oct 5, 2008 08:53 PM
What, No Pics?
TEB-HHR Oct 5, 2008 10:26 PM
We all love pictures :thumb:
halfpanel08 Oct 5, 2008 11:29 PM
im deff. jealous .... :)
kartermdb May 7, 2009 09:17 PM
Put my goldlines in today in about 2 hours and 45 min. Ill get a pic for you guys soon. My 09 panel only has 1000 miles on it now, and already changing parts :nuts:
ballplr May 7, 2009 09:36 PM
congrats :thumb:
ksfis43 Jun 26, 2009 09:18 AM
Alignment after Lowering Spring Install??
Originally Posted by ng8650 (Post 14922)
Also next Monday I'll take it to the alignment shop and let you know how much, if any, the alignment was out.
Ng
Does anyone know, Do you need an alignment after you install the lowering springs??
I would like to install mine before vacation but I don't think I will have time for an alignment, If I need an alignment the install will just have to wait.
