Switch from miles to kilometers
I am trying to figure out how I can make the above change on my own vs. bringing to a mechanic. I need this change in place in order to import my car to Canada as I am in the process of moving back from US.
Originally Posted by puppysmum
(Post 718242)
DIC Vehicle Personalization Your vehicle has personalization capabilities that allow you to program certain features to a preferred setting. All of the features listed may not be available on your vehicle. Only the features available will be displayed on the DIC. The default settings for the features were set when your vehicle left the factory, but may have been changed from their default state since that time. To change feature settings, use the following procedure: Entering Personalization Menu 1. Turn the ignition on while the vehicle is stopped. To avoid excessive drain on the battery, it is recommended that the headlamps are turned off. 2. Press and hold the information and reset buttons at the same time for one second, then release to enter the personalization menu. If the vehicle speed is greater than 2 mph (3 km/h), only the UNITS menu will be accessible. 3. Press the information button to scroll through the available personalization menu modes. Press the reset button to scroll through the available settings for each mode. If you do not make a selection within ten seconds, the display will go back to the previous information displayed. UNITS This feature allows you to select the units of measurement in which the DIC will display the vehicle information. When UNITS appears on the display, press and hold the reset button for at least one second to scroll through the available settings: ENGLISH (default in United States): All information will be displayed in English units. METRIC (default in Canada): All information will be displayed in metric units. To select a setting and move on to the next feature, press the information button while the desired setting is displayed on the DIC. |
