'09 half-panel LS turned SS, $5,000 OBO
5 Attachment(s)
Okay, this is an interesting one. Some of you may remember that I had built an '07 LS into a race-only car, eventually running 153 mph in the mile with it. I then decided to end my illustrious racing career, so what I did was purchase a white '09 half-panel LS with 107,000 miles from a guy in Maryland, then had the ZZP guys up in Michigan swap the 2.0 race engine and six-speed Saab transmission out of the race car (which has been scrapped) and into the previously anemic, 2.2-powered white '09. The result is what you see here. Here are the specs:
2009 Chevy HHR LS body 2.0 liter GM Ecotec Gen 3 LDK engine; 320 whp (dyno sheet available) BorgWarner AirWerks S200SX-E 52/57mm turbo TiAL 38mm wastegate About 1,000 miles on the new engine and transmission; roughly 108,000 on the body Engine currently tuned for 93 pump gas and to be emissions compliant Front-wheel drive, F40 6-speed manual transmission (from a 2007 Saab 9-3) ZZP LNF front-mount air-to-air intercooler Fidanza forged aluminum flywheel South Bend Stage 4 clutch assembly Stock LE5 head Forged Ecotec LNF crank Forged Ecotec 4340 connecting rods Forged and coated JE 2618 LSJ/LE5 pistons ZZP billet engine mounts 82# valve springs/titanium retainers Mototron 80 lb. injectors Fuelab adjustable fuel regulator Stainless steel ZZP HHR catback exhaust 3-inch stainless steel Cobalt/Ion downpipe and exit downpipe GM 34mm LSJ upgraded axles R1 Concepts drilled and slotted front rotors/stock rear drums Six Wheel Vintiques smoothie wheels, 16” x 6.5”, 5 x 110 bolt circle, 5” backspace Four new Wheel Vintiques bowtie-logo steel baby moon center caps for the smoothies, if you can figure out how to get them on the wheels ☹ Four stock HHR wheels and tires Four Continental tires on the stock wheels Four essentially new Cooper tires on the current smoothies Two 225/50ZR-16 Toyo Proxes RA1 racing tires on the other two smoothies AEM boost and AFR gauges (installed on the a-pillar and working, but calibrated for E85, the engine’s previous fuel, so not completely useful) New battery SS front bumper cover (unpadded, with working fog lights and aftermarket grille, and also painted correct Olympic White by me) is currently on the car. Stock front bumper cover still available; would just need to be notched at the bottom to fit over the intercooler. New Lloyd’s “HHR” logo floor mats up front; stock floor mats in the back Brand-new, solid aluminum Sullivan Racing Products clutch, brake and gas pedal covers, not installed Clean title in hand The car runs great--I drove it back 750 miles from Grand Rapids to NYC in September, and it was a little rocketship on the highway :D It has since been parked, but I drive it around the neighborhood every weekend. The car was originally tuned to run on E85 and to make all of its torque and power on the top end (for land-speed racing), which it still does. This makes it a little bit of a dog off the line (you need to stay in the clutch a little longer than you normally would from a standstill, but I got used to that in about 15 minutes). The top-end power is a blast on the highway, however... :twothumbs: I bought an SS front bumper cover and painted it Olympic White, and it's on there now, without padding but with working fog lights and an aftermarket grille (the paint job is serviceable, but not professional). I still have the original front LS bumper cover, however, and this can be put back on, although the bottom will have to be notched to fit around the intercooler. The stock LS rear bumper cover is still on there--I was going to get an SS rear bumper cover, but decided that I liked the combination of SS front bumper and LS rear bumper, in honor of the car's combo-clone status. I have four Wheel Vintique smoothie wheels on there now (in fairly ugly camo green), but I still have the four stock HHR wheels. If you want to swap the stock wheels back on, however, the R1 Concepts aftermarket front calipers will have to be swapped out for stock calipers; the R1's (I found out the hard way) don't fit behind the stock wheels. I may be willing to remedy this myself before the car sells. The engine itself is worth about $5K; I bought the '09 LS for $2,400, so I'm in for about $8K, but I'm starting to get into boating and would like to liquidate my car stuff. So I'm listing this for $5K OBO, and I'm definitely flexible. This is someone's chance to get SS power in a half-panel LS package (the body is very straight--there's a slight dent on the left-rear quarter panel). I have a clean NYS title in hand. Happy to answer any questions--I don't want to hide anything from anyone, so I'm trying to lay out as much info as possible. Thanks! |
Just lost my 06 to an accident.
wish i lived closer to this! |
It’s only a motion away! Check out car shipping
what did u do as to wiring or the harness and ecm ? from using the 2.0 and fitting it in a 2.2 car as i have a complete 2.0 and trans that would be a cool transplant into one of my 2.4 hhrs , thanks dave seems like a great deal for the right guy or gal
Originally Posted by hellshotrod
(Post 836231)
Gary if you are getting into boating you are going to find that making them go fast is a very very expensive proposition. Ask me how I know.... Just looked at the run down of the parts, he's using 80# injectors so my guess is that it's not a DI motor but a PFI. Correct me if I'm wrong. |
No OP activity over 60 days, thread closed.
