2010 SS front calipers and brackets
Old 10-22-2017, 05:37 PM
Ohiocruiser's Avatar
Hello. I have pair of front calipers from my 2010 ss. They have around 50k miles on them. Replaced them with brembo ones around 6 months ago. They've been sitting in garage since then. First $50 takes them. I believe it is straight swap for lt/ls model. You obviously will need new rotors. Prefer to sell localy,since they're heavy. Located in cleveland, ohio area. Can meet within reasonable distance. Thanks.
Ohiocruiser is offline
Old 10-22-2017, 06:02 PM
Yes these brackets will require the SS non Brembo rotors and bolt right up to the LS/LT, a great upgrade for brakes
GLWS
Oldblue is offline
Old 10-23-2017, 10:46 AM
09_silver_ss's Avatar
flat rate usps shipping will be cheap and easy. glws
09_silver_ss is offline
Old 10-23-2017, 12:05 PM
aradmahogany's Avatar
Only the bracket is needed for the upgrade, correct? (obviously larger rotors, too)
aradmahogany is offline
Old 10-23-2017, 12:31 PM
Brackets are included. All you need is the new rotors. Not sure if you can re- use break pads that are in right now. But they look almost new. Also might consider shipping option if not sold within week or two. Thanks.
Old 10-23-2017, 01:43 PM
Yes those calipers and brackets and the larger rotors, like these on my LS.
Attached Thumbnails 2010 SS front calipers and brackets-1b00d4c6-271b-4e40-bafa-1c264f2b339e.jpeg
Oldblue is offline
Old 10-24-2017, 07:09 AM
I dont mean to hijack the thread, but I thought you could just use your existing caliper with the SS bracket and rotor.
Old 10-24-2017, 08:49 AM
You can do that too, I did.
Ok, on with the sale!!
Oldblue is offline
Old 10-24-2017, 09:01 AM
Well I will follow. If you find trouble selling the set I might buy the brackets off you but I live in FLA
Old 12-25-2017, 06:11 AM
Thread closed, no activity in 60 days
Oldblue is offline
flamarallenjr
10
03-27-2017 05:20 PM
cjuetten
22
04-04-2009 06:26 PM
Joe_WaZoo
14
05-07-2007 11:36 PM
Quick Reply: 2010 SS front calipers and brackets
