looking for SS
Old 05-16-2017, 08:32 AM
JGN62's Avatar
looking for SS
Hi,
My name is Glenn and I have been actively checking out HHR SS's in search of a nice low mileage example. I have been little gun shy about purchasing one though until I finished researching. My deepest concerns though are the obvious Porous block. Would anyone be able to confirm if there are specific date codes I should be looking for at which point the casting flaws were rectified.
Thank you in advance!
JGN62 is offline
Old 05-16-2017, 09:18 AM
Technical Moderator
Moved to introductions.
It was only 2008 that had the problem, at this point if it hasn't raised it's ugly head, you shouldn't need to worry. It was not that big a deal to begin with, just a TSB.
donbrew is offline
Old 05-16-2017, 09:43 AM
Welcome to the site, there are several gently driven SS's in our Classified Ads, check them out!
https://www.chevyhhr.net/forums/clas...wanted-ads-16/
Oldblue is offline
Old 05-16-2017, 10:11 AM
Technical Moderator
There were 2 "porosity" things. One was the bolt hole for the AC compressor was too deep, solution is teflon tape on bolt. The other was "bubbles" in the casting; after machining the they turn into holes so that the head gasket does not seal properly, solution was adding gasket shellac to the normally unsealed head gasket.
Unrelated to "porosity" was some oil leakage around the high pressure fuel pump and the front crankshaft seal.
donbrew is offline
Old 05-17-2017, 08:51 AM
JGN62's Avatar
Thank you Gentlemen,
I appreciate your input. I have driven several and appreciate the power and versatility of these vehicles. I was just wanting to make sure they were pretty dependable as I had read some horror stories. The cost of an engine swap sounds like it can be significant.
JGN62 is offline
Old 07-08-2017, 09:49 AM
JGN62's Avatar
Hello,
Well I did mange to get an early build 2008 SS in Victory red. I am very pleased with the purchase for the most part. As we know, buying a used vehicle is a bit of a crap shoot at times, but this one appears to have been treated pretty well. I will replace the four disc brakes rotors with the slotted variety as the originals are pulsating. They look good visually, but after usage start acting up a bit.
It is a manual and has the limited slip option. All in all a pretty fun ride!
Glenn
Attached Thumbnails looking for SS-img_20170121_144631.jpg   looking for SS-img_20170121_142501.jpg
JGN62 is offline
Old 07-08-2017, 10:28 AM
DwRed2LT's Avatar
Welcome and Congrats on the SS purchase.
DwRed2LT is offline
Old 07-09-2017, 07:41 PM
Congratulations! Have a look at the rear LCA bushings, that could be your brake shake!
Oldblue is offline
Old 07-10-2017, 07:36 PM
skyline26's Avatar
nice!
where did you pick it up from?
skyline26 is offline
Old 08-26-2017, 09:07 AM
JGN62's Avatar
Sorry for the late reply, very busy right now. I picked the vehicle up in Chatham Ontario. It had sat for a long time. I made an offer and surprise it was accepted. It is a very fun and useful vehicle and gets a lot of attention. I am very happy with this purchase!
JGN62 is offline
LegatoMuzic
04-19-2009 08:16 PM
SIHHR
19
12-29-2007 06:43 PM
flyhhr
2.4L Performance Tech
35
04-13-2006 11:51 PM
batman5273
Mid East
7
02-06-2006 01:16 PM
SIHHR
12-31-2005 08:28 PM
Quick Reply: looking for SS
