Originally Posted by mojographics
(Post 796975)
According to the recall website, a 2011 is included in the ignition switch recall. From the looks, and feel, of my key cylinder, it hasn;t been replaced. Thanks for the info.
Originally Posted by donbrew
(Post 796983)
If you input your VIN the website will tell you about your car specifically. At least the link I gave you.
The engine light codes are P0010, and P0011, according to Advance. Timing off problem. Sure purrs to be a timing problem? Maybe a second opinion? Thanks |
put "p0010" into the search box. I'll bet you traction control light is on.
You will find this: https://www.chevyhhr.net/forums/how-...13-14-a-28779/ |
The codes could be a result of dirty oil, most likely a faulty solenoid, change them both.
The new ignition keys have a small hole for the fob ring the old keys have a crescent shaped hole |
