problem with editor
Is it me or the site? When editing a post I can ho longer insert, only replace. For instance; when I forget to hit the space bar between word and go back to inset the space the cursor goes to a block instead of a line and anything I type replaces whatever was under the block.
This started about the time other strange stuff went on. |
I haven't noticed but I can try an edit on this crazy post... Seems to be working as expected Maybe.
Edited.... .^^^That bolded text was inserted^^^ |
You didn't hit the "insert" key on your keyboard by mistake, did you?
I've done that before and thought my computer was hosed until I figured out what happened. |
I just added "crazy" to greybeard's first post. No problem, didn't see any block. On my phone.
And then just added "first" to this post. Might be something in your settings? |
Jeez! Who ever noticed there was an insert key on Windows.
Thanks Greybeard. |
I seem to be experiencing the same thing as before. I post & then can't see it ?
Yes, Sleeper, I just fixed one of your posts, it was duplicated , everything seems normal for , Don.
Are you still having issues? |
Thanks Blue, I didn't see any there. But I just deleted my Browsing history, so far seems good again.. (fingers crossed)
I'm ok now that I noticed the insert key.
Don- where is the insert key ?
