2006 Chevy HHR Radiator fan
Relay 50 turns on radiator fan when forced where does that input come from? temperature sensor or ECM temperature GUAGE WORKS FINE? |
Hi Ric, :welcomewagon: to the forums!!
What issues are you facing with your HHR? |
Chevy hhr radiator fan
(Post 857070)
What issues are you facing with your HHR? relay energize s fan. Input to relay doesn’t come on where does it come from temperature sensor or ECM |
Look at post #2 Fan command comes from ECM. ECM looks at signal from temperature sender/switch to tell fan to come on.
My mistake! Here is the diagram for 2006, SOME have a diode near the fan in the harness.
https://cimg5.ibsrv.net/gimg/www.che...cbdb99b37e.png |
Originally Posted by Ric
(Post 857083)
not coming on relay energize s fan. Input to relay doesn’t come on where does it come from temperature sensor or ECM You say the relay is energizing the fan, so that means the fan is working. What is the issue? Is the engine overheating? |
Fan doesn't normally come on unless I turn on the A/C. OR, engine temp hits 217* F, I do believe.
