2010 shifter light
I presume there's a light under the PRNDIL on the shifter that's supposed to light up, especially in the dark, to show you what gear you're in. How do you get to it, and what bulb is required? I have not been able to find this information on line anywhere.
TIA. |
What year?
As I said in the subject, kind sir, 2010.
When all you have is a hammer, everything looks like a nail. |
You pop the bezel off and look for the light bulb looking thing on the side under the PRNDL Who reads titles?
https://cimg5.ibsrv.net/gimg/www.che...2d12916ae7.png |
Originally Posted by donbrew
(Post 902464)
(Post 902467)
(.....Hey mods. Another thread in the "How To" section that shouldn't be.....)
FYI. I did a Search on this site for that bulb. A couple of threads say that shifter bulb is a # 37.
How you get to it, I don't know. Mine's a 5 speed. |
(Post 902469)
#37 bulb, remove the bezel and the console cover there is a bulb holder to be removed and it can be done with the driver’s seat slide all the way to the rear.
The console cover is removed, by first the e brake is pulled up, that cover will pull up to over come the spring clips, then the front piece around the shifter |
| All times are GMT -5. The time now is 09:29 AM. |
