Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Atf (https://www.chevyhhr.net/forums/maintenance-upkeep-50/atf-43445/)
bugflipper Oct 25, 2012 09:37 PM
Atf
When should you flush out the old atf? I am assuming they have the sealed setup that most of the new cars are going to where you have to take it to the quick lube?
Thanks
sleeper Oct 26, 2012 12:38 AM
Under Severe service @ 50K, otherwise 100K, But I don't think I would let any quik lube jockeys do this.
Edit: Yes it is a sealed unit, & no dipstick..
bugflipper Oct 27, 2012 03:15 PM
How would I do it at home? Of coarse I would drop the pan and change the filter. But where does the new ATF go? Assuming there would have to be a plug to add it. I do have an old electronic fuel pump for fluid transfer. I just went over 100k so figured it would be time.
Thanks
donbrew Oct 27, 2012 04:01 PM
Thanks
Use the Search tool, there are a few threads about changing the ATF. Yes there is a plug; top of trans driver side (for fill only tho); Level control hole on pass. side (like old fashioned differential). PM me if you need a Shop manual, or go to the local AutoParts store I understand that there is a Haynes book now.
bugflipper Oct 27, 2012 06:21 PM
Much appretiated.
Radco Nov 9, 2012 05:57 PM
I am a future 2011 owner, So sorry for the dumb question. If ther is no dip stick for the tranny how do you check it? I will buy a manual if the deal goes through tomorrow :)
Thanks
Richard
swerv0428 Nov 9, 2012 05:59 PM
no need to check it since it is sealed.
But if your buying a manual then you aint gotta worry about it. :D:D
Radco Nov 9, 2012 06:18 PM
Good to know Thanks, Im trying to get as much info as I can ,even if the HHR is not inmyu hands yet :)
swerv0428 Nov 9, 2012 09:27 PM
completely understand. I sold mine but i had 75,000 trouble free miles on mine. use the search feature and look over a bunch of posts. There is so much information on this site. you can learn a lot just by reading. Good luck on your search.
