Automatic Transmission Fluid Flush
If you mean a real transmission flush where new fluid is pumped in to force the old fluid out, then I would say it's hard to do it yourself. Assuming you don't have a flush machine, one of the options is to get a bucket of new fluid, disconnect the transmission return cooler line and place it into the bucket of fluid. Then disconnect the cooler line that is the output from the transmission and place it in an empty bucket. Start the car, old fluid will be pumped out of the output line into the empty bucket while new fluid will be sucked out of the bucket with the new fluid. A friend did his GM truck this way. Keep pumping until new fluid runs out of the output line. HOWEVER, some transmissions will pump the fluid out faster than it can be sucked in, possibly running the trans dry momentarily (bad situation). On those you have to add some fluid thru the filler tube as its pumped out.
Given the complexity and possible damage, I'll let my local garage do it for about $100 every 2 or 3 years.
Steve
Steve
hello,
I recently went to jiffy lube to have a transmission flush performed on my 2006 HHR. Since then I have experienced problems with the transmission. I was wondering if anyone else has had problems with a transmission flush and if the procedure can harm the transmission? I currently have 98000 miles on my car. I use the car for business.
Thanks
Thanks
hello,
Thanks
Thanks
check out page 398 in the owner manual (h)
it states that the only time you need to chenge the fluid and filter if the vehicle is driven under one or more of these conditions
_in hevey city traffic where the outside temp regularly reaches 90 or higher
-in hilly or mountaions terrain
-when doing frequent towing
-uses such at a taxi,police
,or delivery service
if you do not use you vehicale under any of there conditions ,the fluid and the filter do not require changing
,or delivery service if you do not use you vehicale under any of there conditions ,the fluid and the filter do not require changing
-uses such at a taxi,police ,or delivery service
I use the car for my delivery job at the St. Louis airport where I deliver lost luggage for the airlines.
Flushing is a big money maker for places like Jiffy Lube, but simply draining the fluid and replacing the filter is sufficient in most cases and will not cause unwanted debris to be broken loose and foul the rest of the transmission.
I'm going to have my transmission drained and refilled with a new filter in a couple thousand miles at 50k, but I also drive in hilly terrain for my job and I've put over 30k on the car since last year. I think those two factors, the mileage and frequent downshifting in the hills, probably make my car meet the severe service interval for the transmission.
hello,
Thanks
Thanks
