Battery
Old Dec 12, 2014 | 08:25 AM
Battery
A group 48 battery will fit. It has the vent system and 850 CCA. About 1.5 inches longer and 1 inch higher. Oldblue has one for confirmation of fit.
(that should say group 47/H5)
Old Dec 12, 2014 | 08:43 AM
Ok. Gotta ask.
I did a search for Group 48 batteries. Most of what I see is 700-730 CCA. Also didn't see any that showed the vent system our HHR's need.
Does Oldblue have a certain brand battery that has the specs you listed ?
Old Dec 12, 2014 | 09:53 AM
The NAPA batteries group 48 & 49 have vent holes and elbows included. Don't know if it's something new or specific.
Old Dec 12, 2014 | 10:01 AM
My battery was installed by AAA guy it has the vent tubes it is labeled AAA battery I don't know who made the battery, but it is a group 48
Old Dec 12, 2014 | 11:38 AM
2005HHRauto's Avatar
Come on guys, this is the 21st century ...
Get an AGM battery , no vents needed, & will last twice as long,
as a 20th century old fashion 'flooded' type antique battery.
Also, no need for a Group 48 (H6) , When a Group 47(H5),
is the same length as our battery, for an easy install...
Long-lasting DieHard Gold size 47 Car Batteries are ideal for replacing your current car or truck battery. This all climate DieHard Advanced Gold battery features AGM technology that is designed to provide more power and longer life.
Featuring 2x the Cycle Life, the DieHard Gold 47 Battery performs throughout the life of the battery. And with faster recharging powers you'll always have enough power to get started and keep your car running.
DieHard Gold Size 47 Car Batteries are built with an enhanced electronic suspension system that absorbs more electrolyte and protects internal components.
Spill-proof Design provides added protection for sophisticated electronic equipment and your engine compartment.
20x More Vibration Protection (than regular Diehard batteries) safeguards battery performance over time.
Flat-Plate AGM Design provides the most efficient use of internal volume for more power
More than 250 Quality Control Checks ensure the longest life and durability.
Made in the USA
Backed by manufacturer's 36 month replacement warranty.
Better warranty
Limited 3 year full replacement warranty — not pro rata.
Longer service life
3-10 years of service life to save you time, money, and aggravation
Longer cycle life
70% longer cycle life than conventional deep cycle batteries — high stable voltage for longer periods of time.
Longer shelf life
Can be stored on open circuit (nothing connected to the terminals) without recharging for up to 2 years or 12.00V, whichever occurs first.
Faster recharge
The highest recharge efficiency of any sealed lead battery on the market — capable of 100% recharge in 4-6 hours.
Mounting flexibility
Non-spillable design — can be mounted on any side in any position except inverted.
Vibration resistance
Design protects against high impact shock and mechanical vibration — a common cause of premature battery failure.
Extreme temperature tolerant
Operating temperatures from -40°C (-40°F) to 45°C (113şF), for models without a metal jacket, and from -40şC (-40şF) to 80şC (176şF) for models with a metal jacket.
Totally maintenance free
No need to add water, ever! Drycell design.
Improved safety
US Department of Transportation classified as a ‘non-spillable’ battery.
No acid spills, no escaping gases.
Two Group 47(H5) AGM battery links:
Duracell AGM Automotive Battery - Group Size 47 (H5) - Sam's Club
Sears.com
Old Dec 12, 2014 | 12:19 PM
I see no mention of CCA.
Old Dec 12, 2014 | 12:33 PM
Me either, and mine was just $114.00 installed it has been just fine for almost 5 years
Old Dec 12, 2014 | 12:53 PM
CCA is really so old-school…
"flooded' vs AGM , reminds me of , carburetors vs fuel injectors, & showing my age, (62) , black/white vs color TVs
Some guys just don't like the better modern technology...
AGM batteries have more plate-surface-area, in the same size 'box', as the antique 'flooded' type batteries.
AGM batteries provide enormous cranking power, & deep cycle reserve power.
The AGM batteries are the best of both worlds...
AGM batteries are capable of providing engine cranking pulses in excess of double to triple that of equally sized conventional batteries, even at very low temperatures. And they can handle 400 charge-discharge cycles to 80% depth of discharge.
$134 for an AGM battery that will last twice as long as your's, is a better deal…
Sears, with there sales & discount 'points' , a better deal also…
I run this light-weight 20lb battery in the winter, that's rated at 400CCA
ODYSSEY Batteries - PC950-P
During the racing season, I run this 5lb battery, that's rated at 540CCA
Shorai LFX36L3-BS12 Lithium-Iron Battery - Free Shipping: BatteryMart.com
Old Dec 12, 2014 | 01:06 PM
I see the price of $ 217.47 not $134.00 but I will consider AGM next time I need a battery.
But 400 CCA is very low for me
Old Dec 12, 2014 | 02:17 PM
$134 at SAMs club , link in post #5
CCA is the old-school 'flooded' battery thing...
AGM batteries have 2-3 times the cranking power...
