Body control module
Hi all. Quick question. Will a BCM from a 2008 LT non panel work in a 2008 LS panel? With the proper flashing, of course
It should.
2008 LT and Panel both list the same part # for the BCM.....25928052 |
Why? I doubt the computer is your problem.
If this is about your gate ajar problem you should have mentioned you had a panel in the thread that you stated you had the same problem. Panel gate is wired differently. |
BCMs are a one time flash module. Used BCMs cannot be reflashed to a new vehicle.
