Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   cabin air filter INTAKE (https://www.chevyhhr.net/forums/maintenance-upkeep-50/cabin-air-filter-intake-25187/)
Budro Aug 17, 2009 12:24 PM
anyone know where the intake for the cabin air filter is?? Got a nasty smell when air cond is turned on. I have changed the filter 2 times, and no better. Goes away in a couple of minutes. I want to spray some lysol in the intake, :confused:but I don't know where it is:red:-----Budro
outlandishhhr Aug 17, 2009 12:27 PM
The Cabin air filter is located behind the glove box. If you open it all the way you will see two little tabs holding it up, push those towards each other and the glove box will fold down nicely. You'll be looking for a little cover with snap type tabs. Let me know if you need more info
Budro Aug 17, 2009 12:30 PM
filter
I know where the filter is. I need to know where the intake for the filter is---Budro
tomw Aug 17, 2009 12:42 PM
The A/C smells like that whether the Cabin filter is old or new......
xzombiex66 Aug 17, 2009 12:49 PM
Mine smells like this too, pisses me off.
txbass06 Aug 17, 2009 12:50 PM
Next time you get the car out, try turning the A/C off but leave your fan running and see if that helps. Ford (I think) had an issue with bacteria building up in the A/C condensor and causing a mildew smell when the A/C was turned on. Leaving the fan running without the compressor will help dry out the condensor and keep that smell down
xzombiex66 Aug 17, 2009 12:52 PM
I do it every time, doesn't help
Budro Aug 17, 2009 12:54 PM
Where is the intake
txbass06 Aug 17, 2009 12:54 PM
It helped mine a little. Still stinks to high hell sometimes though...
xzombiex66 Aug 17, 2009 01:19 PM
Originally Posted by Budro (Post 405295)
Where is the intake
I have no idea, normally its up around the windshield cowl. that plastic piece at the bottom of the windshield.
