change oil soon message
Old Mar 23, 2012 | 09:25 AM
Bob Cavicchio's Avatar
When you do your own oil change, will this message go away automatically, or do you have to do something to "reset" it?
Old Mar 23, 2012 | 09:28 AM
Putter's Avatar
After I change mine, I just turn on the key (don't start it) and press/release the accelerator repeatedly. (it's something like 7 or 10 times). That resets the oil life counter.
Old Mar 23, 2012 | 09:47 AM
kb0sdq's Avatar
I turn the key on (not started) press the info button on the steering wheel scroll thru to you get to oil life then press and hold the reset button looks like a left arrow this should reset oil life back to 100%
hope this helps,
Old Mar 23, 2012 | 10:10 AM
db/sb's Avatar
It's 3 times within 5 seconds.......that's the standard GM oil life reset for cars w/o a D.I.C. but it also works on the HHR.
Old Mar 23, 2012 | 11:57 AM
X 2, works fine on mine.. Also standard practice for wifeys Mopar..
Old Mar 24, 2012 | 07:52 AM
Thanks everyone!
Old Mar 24, 2012 | 08:20 AM
bowtieboy68's Avatar
i had not heard about this technique!
will have to give it a try next time
Old Mar 24, 2012 | 09:53 AM
db/sb's Avatar
See post #3 for the correct number of accelerator pumps....
Old Apr 9, 2012 | 10:50 AM
hope this helps,
That method worked for me. Did not have luck pumping the pedal. Thanks!
Old Apr 9, 2012 | 05:03 PM
Same here. Tried the "gas pedal 3 pump method". Didn't work for my 2010 SS. Must just work for certain year/models.
