Charcoal Canister Seal
Old Mar 24, 2023 | 11:31 PM
hhrumadbruh's Avatar
Originally Posted by greg8453
You have just the one code for large evap leak? That is not causing the smoke under load. Are you consuming oil? Does the car accelerate OK?
The smell could be from the EVAP.
Yeah that and a knock sensor code.
tiny oil dripping from bottom of the car but oil level in the dipstick is good.
slow coolant level drop. Once a week I need to top off the reservoir.
trace amount of oily residue on top of coolant in fill cap.
Car will sputter, act as if it's going to stall out, rpm fluctuates if given a minimal amount of pedal but will act fine if given over 1500 rpm.
Old Mar 25, 2023 | 08:38 AM
PulpFriction's Avatar
Yeah, the evap leak probably isn't causing all your other problems but you already know that. What other codes besides P0455?
Old Dec 12, 2024 | 05:38 PM
guppy's Avatar
Thanks Jon! Same issue, replaced the purge valve and did not even realize there was an o-ring on it. After a year I failed the inspection test and decided to dig deeper when I stumbled across this post. I used two 13mm I.D. O-rings and a 15mm I.D. O-ring and engine code cleared itself in a couple days. Thanks!!
Old Dec 13, 2024 | 06:52 AM
Good thanks for posting the oring sizes for future readers.
TiggersHHR
"How To" Tutorial Library
65
Feb 2, 2026 08:07 AM
HHRnovice
Mar 22, 2021 02:00 PM
foxtrotraptor
Mods - Engine/Exhaust
20
Sep 17, 2013 11:41 PM
frey55
2.4L Performance Tech
7
Apr 21, 2010 07:48 AM
