Originally Posted by greg8453
(Post 936140)
You have just the one code for large evap leak? That is not causing the smoke under load. Are you consuming oil? Does the car accelerate OK?
The smell could be from the EVAP. tiny oil dripping from bottom of the car but oil level in the dipstick is good. slow coolant level drop. Once a week I need to top off the reservoir. trace amount of oily residue on top of coolant in fill cap. Car will sputter, act as if it's going to stall out, rpm fluctuates if given a minimal amount of pedal but will act fine if given over 1500 rpm. |
Yeah, the evap leak probably isn't causing all your other problems but you already know that. What other codes besides P0455?
