Originally Posted by Cat Man HHR
(Post 848232)
Why? There are no high and low pressures shown.
Find out before you overthink the wheel. K.I.S.S. Seen it many times, all kinds of equipment. like I said, just guessing without actual pressures. :smile: |
Ac
I will try to get them today.
Originally Posted by J W Davis
(Post 848355)
His quote stated that the pressure would equalize after turning it off
Knowing ambient air temperatures and the low and high side pressures when in use can help in the diagnosis. K.I.S.S. = "Keep It Simple Stupid" |
Ac
Thank you, I look into it in a few. I did bleed some off yesterday and drove about an hour. It did cool down in the 93 degree temp here in Atlanta. Mostly when stopped in traffix or at a steady speed at about 40, or 65. But it did go warmer but not hot. I will be getting pressures in a while. Although I will be quessing as to how much refrigerate is in the system. I thought it might just be easier to vacuum it out and put 14.4 Oz back into it. (.9 lbs).
Might be if you know what you are doing.
filter, PAG, vacuuming correctly etc. |
If you're going to post up the pressures, you need all the stats.
Static pressure-gauges hooked up, nothing running. Working pressures, high and low with AC operating. Outside/ambient temperature FYI. I wouldn't post up anything about "bleeding off" freon into the atmosphere. The EPA feds may come to see you. :skull1: |
Ac
No I take to get the system properly discharged. It is easier to say bleed.
Originally Posted by Scorangehhr
(Post 848422)
edit. I'm starting to doubt the validity of this story. Since the OP hasn't returned in a week now, we either scared him off or it wasn't what it originally appeared to be. |
Or he just found his answers/fix elsewhere
