Coolant drain/flush/refill
Old Feb 10, 2011 | 03:14 PM
CCK- The Dex-Cool has a much longer life than regular Prestone green..
Not sure how compatable a mix of both would be ? Since I'm still under warranty, & also because of the entended life. I'll stick with the recommended Dex-Cool
Old Feb 10, 2011 | 03:40 PM
ChevyMgr's Avatar
If you mix dex-cool and green coolant you get the life span of the the green. I wouldn't do that. If you want to flush your radiator every 2 years or so use green. I don't remember if it was 24K or 30K that it was recommended by GM to flush the green. If you want to have 150K coolant use dex-cool.
The only GM vehicles that had problems with dex-cool were the 1995-2003 3.1L, 3.6L and 4.3L engines. There may have been others that I am not remembering, but all were V6s.
The problem was it turned to mud in those vehicles when the coolant level was allowed to run low, but not low enough to turn a light on. Plugged radiators and heater cores were the norm on those vehicles.
There was a class action suit that was lost by GM on those vehicles. The bad part was the lawyers got $16 million and claimants got $50-$800 each, depending on what related repairs had been paid for. Owners had to submit a claim by 2008.
Old Feb 10, 2011 | 03:47 PM
Super Moderator-
Thank's for clarifying the situation
Old Feb 10, 2011 | 04:19 PM
Snoopy's Avatar
Notice, if I'm not mistaken, all the "problem" engines are IRON BLOCK.
Old Feb 10, 2011 | 04:24 PM
Good point Snoopy,
I know the 4.3 was an Iron Block for sure.
Old Feb 10, 2011 | 04:31 PM
Snoopy's Avatar
Originally Posted by sleeper
Good point Snoopy,
OK, I'll add a little more.....
I was TOLD, by undisclosed sources, that GM originally used the Dexcool in aluminum blocks...trucks, etc. with great success. They made an erroneous transition to the iron blocks with Dexcool and did not do adequate testing (remember, I was one....in a 3.1 Lumina).
Old Feb 10, 2011 | 08:55 PM
urbexHHR's Avatar
Yeah, and the car could only be like 5 years old... Most cars with the 3.1 were over that age by then, mine included... I had to pay full price out of pocket to get it fixed...
Old Feb 10, 2011 | 09:15 PM
bk94si's Avatar
Is there any difference between Dex-cool and the Prestone orange long-life stuff?
Old Feb 10, 2011 | 10:00 PM
Snoopy-
Very interesting !!! Thanks for the info !!!
& afterthought, my former 4.3 had Iron heads as well..
Old Feb 10, 2011 | 10:01 PM
Good question, IDK ??
