Creaking
Old 04-20-2019, 06:54 PM
Pothole340's Avatar
Creaking
Just inftslled new LCAs now I have a horrible creaking noise sounds like the car is gonna tear apart we loosened all the bolts pushed it up and down tetightened them all never seeze the bushings sounds like it’s coming from the.horizonal bushing I don’t know what to do or look for it was quiet before just the noise from the rear bushing can someone help
Pothole340 is offline
Old 04-20-2019, 08:11 PM
Are they the poly bushings ?
sleeper is offline
Old 04-20-2019, 08:34 PM
Pothole340's Avatar
Creak
Not sure but it’s very frustrating when you contact the ppl you buy them from and they say you must have something wrong with your chassis when it didn’t do it before the instsllstion
Old 04-20-2019, 09:52 PM
Poly bushings are very different that rubber. The difference should be obvious.
sleeper is offline
Old 04-20-2019, 10:27 PM
Technical Moderator
Both sides?
do you have an SS?
when does it creak?
You could try squirting WD40 on 1 spot at a time to narrow it down.
look at the isolators on the springs.
look at the sway bar bushings and end links.
donbrew is offline
Old 04-21-2019, 07:19 AM
Pothole340's Avatar
Cresking
All new didn’t make the noise till I put on control arm
Old 04-21-2019, 08:01 AM
What brand and part number did you use?
Are they stamped steel?
Or cast aluminum?
Oldblue is offline
Old 04-21-2019, 10:06 AM
Technical Moderator
All new? complete Struts (shock,spring,mount), sway bar bushings, sway bar end links, LCA. Nothing else moves
Check the 3 nuts on the top strut mountings.
Important questions: is it an SS? Under what conditions does it creak?
donbrew is offline
k5hart
05-29-2019 09:09 AM
Levi
11-03-2014 06:54 PM
MikeX
03-21-2009 07:49 PM
jbbadboy
02-08-2009 08:14 AM
Kingfrog
09-14-2007 11:45 AM
Quick Reply: Creaking
